[AG-TECH] Renaming service managers
Ryan McVeigh
rmcveigh at ucar.edu
Thu Jan 10 17:04:17 CST 2008
The hostnames properly resolve from the display machine in that the
host machine can find the other. But I'm not sure that the
configuration is being saved properly or that I'm loading the newly
saved node config. The only step I've attempted is changing the
configuration in the AG node management by starting from scratch and
when I go to fill in the new names in the Add Service Manager Dialog
box and hit OK the name shows up as it was before within the node
management window. Is there a step I am missing?
Ryan McVeigh
National Center for Atmospheric Research
On Jan 10, 2008, at 3:54 PM, Thomas D. Uram wrote:
> I'm sure the AG software is not meddling with the hostnames, as it
> does no special caching of hostnames or anything. Two things come
> to mind:
> - Are you sure that the node configuration is being saved properly,
> using the new names? Are you sure you are loading the newly saved
> node configuration?
> - Do the new hostnames properly resolve from the display machine?
> Tom
> On 1/10/08 4:42 PM, Ryan McVeigh wrote:
>> Hey everyone,
>> Our network team changed our network to DHCP over the holidays and
>> changed the network names of our multi-node system. Now neither pc
>> can find each other within the Access Grid software. If I try to
>> create a new configuration in AG node management it changes the
>> name/IP to the name used prior to the network change.
>> How do you rename the service managers/computers within the AG
>> software so that they recognize each other?
>> Thanks,
>> Ryan McVeigh
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080110/72b28a8d/attachment.htm>
