[AG-TECH] Renaming service managers
Thomas D. Uram
turam at mcs.anl.gov
Thu Jan 10 16:54:11 CST 2008
I'm sure the AG software is not meddling with the hostnames, as it does
no special caching of hostnames or anything. Two things come to mind:
- Are you sure that the node configuration is being saved properly,
using the new names? Are you sure you are loading the newly saved node
configuration?
- Do the new hostnames properly resolve from the display machine?
Tom
On 1/10/08 4:42 PM, Ryan McVeigh wrote:
> Hey everyone,
> Our network team changed our network to DHCP over the holidays and
> changed the network names of our multi-node system. Now neither pc can
> find each other within the Access Grid software. If I try to create a
> new configuration in AG node management it changes the name/IP to the
> name used prior to the network change.
> How do you rename the service managers/computers within the AG
> software so that they recognize each other?
> Thanks,
> Ryan McVeigh
> National Center for Atmospheric Research
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080110/51fb98be/attachment.htm>
