[AG-TECH] Equiptment ideas?
Ben Green
ben.green at manchester.ac.uk
Tue Aug 12 05:17:56 CDT 2008
An AG related projecthere at Manchester uses 2 Sony Camcordersconnected toa dual port firewire PCMCIA card, plugged into a laptop. They're much cheaper than VC cameras with an equivalent optical quality. In fact, I think the optical zoom is even better with most camcorders. You'd have to use the IR remote controls to zoom though, and wouldn't get any tilt/pan control. Ben. From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Douglas Baggett Sent: 11 August 2008 21:30 To: ag-tech Subject: Re: [AG-TECH] Equiptment ideas? What about a good high end Firewire video camera? I'm looking to put one on a Mac Pro? Any ideas -Doug B OCI/NSF On Aug 11, 2008, at 3:53 PM, Matthew Leszczenski wrote: I have looked at the RAV 600, and that is more for a full room node, whereas this node is in a public space, so the table microphones would not work as well to pick up just the sound we want, compared to the ambient noise around it, and unfortunately the RAV 600 has its own proprietary connection for its microphones to the main system, so it cannot be expanded upon except with other ClearOne microphones directly made for the RAV systems. Thank you though! Matthew Leszczenski - Technical Assistant and Eagle Scout - Undergraduate NSSA Major @ RIT - Collaboration Technology Developer @ RIT Research Computing department From:Tran, Quang V. [mailto:qtran3 at lsuhsc.edu] Sent:Monday, August 11, 2008 3:06 PM To:Matthew Leszczenski;ag-tech at mcs.anl.gov Subject:RE: [AG-TECH] Equiptment ideas? Hi Matthew, Check out the RAV 600:http://www.clearone.com/revolutionary-audio-conferencing.html. Quang Tran LSUHSC From:owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On Behalf OfMatthew Leszczenski Sent:Monday, August 11, 2008 1:20 PM To:ag-tech at mcs.anl.gov Subject:[AG-TECH] Equiptment ideas? Hello all, One of my current projects is a public AG kiosk-like setup, in which people will be able to walk up to the node, choose a stream and start to talk directly with that stream. The area is about a 12' X 12' square area, with drop-tile ceiling, it will consist of 1x HD camera, 1x DV camera, 2x 52" HD LCD TV' s, 1x high quality microphone, some sort of directional speakers, and an echo cancellation system. It seems that I would only need one microphone input for this project. However I have mostly worked with the ClearOne XAP400, which is a dual line-in echo cancellation system, and the XAP does not seem to come in a single line-in version. Is there some other echo cancellation unit that people would suggest for a setup like this? Or have I missed a single line-in version of the XAP? Also any other suggestions for the node would be nice to hear, in case others have ideas that haven' t been thought of, or others are thinking of building a node such like this. As always all help is appreciated! Matthew Leszczenski - Technical Assistant and Eagle Scout - Undergraduate NSSA Major @ RIT - Collaboration Technology Developer @ RIT Research Computing department
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080812/77d658ab/attachment.htm>
