[AG-TECH] Equiptment ideas?
Douglas Baggett
dbaggett at nsf.gov
Mon Aug 11 15:29:34 CDT 2008
What about a good high end Firewire video camera? I'm looking to put
one on a Mac Pro? Any ideas
-Doug B
OCI/NSF
On Aug 11, 2008, at 3:53 PM, Matthew Leszczenski wrote:
> I have looked at the RAV 600, and that is more for a full room node,
> whereas this node is in a public space, so the table microphones
> would not work as well to pick up just the sound we want, compared
> to the ambient noise around it, and unfortunately the RAV 600 has
> its own proprietary connection for its microphones to the main
> system, so it cannot be expanded upon except with other ClearOne
> microphones directly made for the RAV systems. Thank you though!
> Matthew Leszczenski
> - Technical Assistant and Eagle Scout
> - Undergraduate NSSA Major @ RIT
> - Collaboration Technology Developer @ RIT Research Computing
> department
> From: Tran, Quang V. [mailto:qtran3 at lsuhsc.edu]
> Sent: Monday, August 11, 2008 3:06 PM
> To: Matthew Leszczenski; ag-tech at mcs.anl.gov
> Subject: RE: [AG-TECH] Equiptment ideas?
> Hi Matthew,
> Check out the RAV 600: http://www.clearone.com/revolutionary-audio-conferencing.html
> Quang Tran
> LSUHSC
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]
> On Behalf Of Matthew Leszczenski
> Sent: Monday, August 11, 2008 1:20 PM
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] Equiptment ideas?
> Hello all,
> One of my current projects is a public AG kiosk-like
> setup, in which people will be able to walk up to the node, choose a
> stream and start to talk directly with that stream. The area is
> about a 12’ X 12’ square area, with drop-tile ceiling, it will
> consist of 1x HD camera, 1x DV camera, 2x 52” HD LCD TV’s, 1x high
> quality microphone, some sort of directional speakers, and an echo
> cancellation system. It seems that I would only need one microphone
> input for this project. However I have mostly worked with the
> ClearOne XAP400, which is a dual line-in echo cancellation system,
> and the XAP does not seem to come in a single line-in version. Is
> there some other echo cancellation unit that people would suggest
> for a setup like this? Or have I missed a single line-in version of
> the XAP? Also any other suggestions for the node would be nice to
> hear, in case others have ideas that haven’t been thought of, or
> others are thinking of building a node such like this.
> As always all help is appreciated!
> Matthew Leszczenski
> department
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080811/ee93c8ae/attachment.htm>
