[AG-TECH] Add Shared Whiteboard
Channa Tang
channa.tang at gmail.com
Wed Sep 14 05:10:14 CDT 2005
Hi Chris
I have done what you said and the location it prints out is:
d:\documents and settings\localadmin.CCBUILD130D
so I put the mlb directory and SharedMLB.agpkg there, and ran
SharedMLB.agpkg again, and tried to invoke it from the MLB
Controller's Start button, but it still didn't work.
Then, I just modified the name of the mlb directory from "mlb-1.1" to
"mlb" and it works now. I don't know if this is the reason why it
didn't work before.
Thanks again for your help!
By the way, could you give me some advice if I want to do something
more about the AG programs? Where could be a good start?
Best regards
Channa
On 14/09/05, Christoph Willing <willing at itee.uq.edu.au> wrote:
> On 13/09/2005, at 8:18 PM, Channa Tang wrote:
> > Hi Chris
> > Thank you for your reply.
> > I have unzipped the mlb-1.1.zip file into my home directory:
> > D:\Documents and Settings\localadmin
> > MLB works OK if I use mlb.exe, but it still doesn't work when I invoke
> > it from the MLB Controller's Start button.
> Channa,
> The shared app uses a technique to find the mlb directory and mlb.exe
> which may not work very well on Windows. Could you create a plain
> text file with the following lines in it?
> #!/usr/bin/python
> import os
> print os.path.expanduser("~")
> ##### end of file #########
> Save it as something like atest.py, then run it from a command shell
> and tell me what it prints out (whatever location it prints out is
> where the shared app is expecting to find the mlb directory).
> chris
> > On 13/09/05, Christoph Willing <willing at itee.uq.edu.au> wrote:
> >> On 13/09/2005, at 11:47 AM, Christoph Willing wrote:
> >>> On 13/09/2005, at 2:23 AM, Channa Tang wrote:
> >>>> Thank you for your replys.
> >>>> I have installed AGTK 2.4 in Windows XP and downloaded MLB for
> >>>> Windows
> >>>> and SharedMLB.agpkg, but when I click on "Start MLB" button in MLB
> >>>> Controller, the mlb application will not start itself. Does anyone
> >>>> know why?
> >>> Channa,
> >>> There are 2 ways of running MLB within the AG; either as a Node
> >>> Service or as a Shared Application. It looks like you're using the
> >>> second method and the Windows version of this was never completed,
> >>> meaning that the mlb executable isn't actually run. I'll try to
> >>> find some time to fix it in the next few days.
> >> Channa,
> >> You need to unzip the mlb-1.1.zip file (which you downloaded from the
> >> "MLB for Windows" link) into your home directory. If your account
> >> name is "channa", then your home directory will be:
> >> C:\Documents and Settings\channa
> >> After unzipping, you should end up with an "mlb" directory in your
> >> home directory. In turn, the "mlb" directory will contain some more
> >> directories and some files, including mlb.exe, which you could test
> >> as a standalone application first. If that works OK, then it will
> >> work when you invoke it from the MLB Controller's Start button.
> Christoph Willing +61 7 3365 8350
> QPSF Access Grid Manager
> University of Queensland
