[AG-TECH] Add Shared Whiteboard
Channa Tang
channa.tang at gmail.com
Tue Sep 13 05:18:34 CDT 2005
Hi Chris
Thank you for your reply.
I have unzipped the mlb-1.1.zip file into my home directory:
D:\Documents and Settings\localadmin
MLB works OK if I use mlb.exe, but it still doesn't work when I invoke
it from the MLB Controller's Start button.
Do you know why?
Thanks a lot in advance!
Best regards
Channa
On 13/09/05, Christoph Willing <willing at itee.uq.edu.au> wrote:
> On 13/09/2005, at 11:47 AM, Christoph Willing wrote:
> > On 13/09/2005, at 2:23 AM, Channa Tang wrote:
> >> Thank you for your replys.
> >> I have installed AGTK 2.4 in Windows XP and downloaded MLB for
> >> Windows
> >> and SharedMLB.agpkg, but when I click on "Start MLB" button in MLB
> >> Controller, the mlb application will not start itself. Does anyone
> >> know why?
> > Channa,
> > There are 2 ways of running MLB within the AG; either as a Node
> > Service or as a Shared Application. It looks like you're using the
> > second method and the Windows version of this was never completed,
> > meaning that the mlb executable isn't actually run. I'll try to
> > find some time to fix it in the next few days.
> Channa,
> You need to unzip the mlb-1.1.zip file (which you downloaded from the
> "MLB for Windows" link) into your home directory. If your account
> name is "channa", then your home directory will be:
> C:\Documents and Settings\channa
> After unzipping, you should end up with an "mlb" directory in your
> home directory. In turn, the "mlb" directory will contain some more
> directories and some files, including mlb.exe, which you could test
> as a standalone application first. If that works OK, then it will
> work when you invoke it from the MLB Controller's Start button.
> chris
> Christoph Willing +61 7 3365 8350
> QPSF Access Grid Manager
> University of Queensland
