[AG-TECH] Problems configuring a laptop client.
Brian Tieman tieman at aps.anl.gov
Fri Feb 25 15:42:52 CST 2005
I uninstalled and then deleted all environment variables relating to
globus--one of which was GLOBUS_HOSTNAME.  After reinstalling,
everything now seems fine--Thanks!!
Brian
Eric Olson wrote:
>Hi Brian,
>It sounds like unsetting the windows environment variable GLOBUS_HOSTNAME
>could help.
>Here's a previous discussion of this:
>http://www-unix.mcs.anl.gov/web-mail-archive/lists/ag-tech/2004/06/msg00022.html
>If that doesn't fix everything, there is the possibility that you have an
>old node configuration causing problems.  We should be able to
>tell from looking at your logs.
>Eric
>On Fri, 25 Feb 2005, Brian Tieman wrote:
>>Hi all!
>>I'm tring to set up a VenueClient on my laptop.  I've installed python,
>>wxpython and the AGTK2.3--exactly as I have on several other machines.
>> The problem is that on the laptop when I run the venueClient, it takes
>>forever to start.  It will eventually start--and I can connect to venues
>>and do most things.  The problem is that I can't open up the "Manage my
>>node" tool and configure my node--I can't connect to the node manager..
>>I used to have AGTK2.1 installed on this machine, but I never had it set
>>up for any AV.  I believe I've uninstalled everything properly and
>>scoured any remaining files from my machine.  After installing the
>>AGTK2.3 and running the debug venueClient, I get the errors below.
>>Any advice on what to do would be greatly appreciated!
>>Thank You!
>>Brian
>>*** Method ServiceManager:AddServicePackage exception ******************
>>Traceback (most recent call last):
>>  File
>>"C:\software\AccessGrid\build\dist-20040910_210059\Lib\site-packages\SOAP
>>py\Server.py", line 407, in do_POST
>>  File
>>"C:\software\AccessGrid\build\dist-20040910_210059\Lib\site-packages\Acce
>>ssGrid\AGServiceManager.py", line 484, in AddServicePackage
>>  File
>>ssGrid\AGServiceManager.py", line 109, in AddServicePackage
>>    server.RegisterObject(nsi, path="/NodeService")
>>  File
>>ssGrid\AGServiceManager.py", line 269, in AddService
>>Exception: Error starting service
>><Fault SOAP-ENV:Server: Method Failed: ServiceManager:AddServicePackage>
>>  File
>>  File
>>  File
>>  File
More information about the ag-tech mailing list
