[AG-TECH] Problems configuring a laptop client.
Andrew Patrick
Andrew.Patrick at nrc-cnrc.gc.ca
Fri Feb 25 15:22:43 CST 2005
Any chance this is a Thinkpad?
If so, the IBM utilities rely on an earlier version of Python, and the
environment variables that are set interfere with the AG. Adjusting those
variables is easy.
If it is a Thinkpad, let me know and I will lookup the procedure, or search the
archive of previous discussions here on ag-tech.
Brian Tieman wrote:
> Hi all!
> I'm tring to set up a VenueClient on my laptop. I've installed python,
> wxpython and the AGTK2.3--exactly as I have on several other machines.
> The problem is that on the laptop when I run the venueClient, it takes
> forever to start. It will eventually start--and I can connect to venues
> and do most things. The problem is that I can't open up the "Manage my
> node" tool and configure my node--I can't connect to the node manager..
> I used to have AGTK2.1 installed on this machine, but I never had it set
> up for any AV. I believe I've uninstalled everything properly and
> scoured any remaining files from my machine. After installing the
> AGTK2.3 and running the debug venueClient, I get the errors below.
> Any advice on what to do would be greatly appreciated!
> Thank You!
> Brian
> *** Method ServiceManager:AddServicePackage exception ******************
> Traceback (most recent call last):
> File
> "C:\software\AccessGrid\build\dist-20040910_210059\Lib\site-packages\SOAP
> py\Server.py", line 407, in do_POST
> File
> "C:\software\AccessGrid\build\dist-20040910_210059\Lib\site-packages\Acce
> ssGrid\AGServiceManager.py", line 484, in AddServicePackage
> File
> ssGrid\AGServiceManager.py", line 109, in AddServicePackage
> server.RegisterObject(nsi, path="/NodeService")
> File
> ssGrid\AGServiceManager.py", line 269, in AddService
> Exception: Error starting service
> <Fault SOAP-ENV:Server: Method Failed: ServiceManager:AddServicePackage>
> File
> File
> File
> File
Andrew Patrick, Ph.D.
Senior Scientist
Information Security Group, Institute for Information Technology
National Research Council (NRC), Ottawa, Canada
E-mail: Andrew.Patrick at nrc-cnrc.gc.ca
WWW - NRC: http://iit-iti.nrc-cnrc.gc.ca
WWW - Personal: http://www.andrewpatrick.ca
Phone: (613) 991-3374 Fax: (613) 952-7151 Cell/SMS: (613) 277-9211
