[AG-TECH] Vic.exe error
Thomas D. Uram
turam at mcs.anl.gov
Tue Feb 22 12:31:23 CST 2005
I think you mean that you can receive, but not transmit.
I've seen this problem when the selected capture source is no longer present, which can be
the case if the camera has been unplugged, or the card has been removed from the machine.
In either case, you can't get data through the selected driver.
Make sure the camera works in other applications, note the driver, and try to use the same
one in vic. If you have problems here, update/reinstall the camera driver.
Do you have multiple options for capture source in the 'configure on transmit' window?
Tom
Nora Barry wrote:
> Hi,
> I have not been able to receive video, tho I can transmit it.
> I followed the tutorial for video troubleshooting. The steps I took were
> these:
> à Encoder
> à Options
> à Configure on transmit
> à Video format
> à Camera controls
> à Capture source
> When I hit apply in capture source, I received a “vic.exe” error and it
> shut down. This has happened 4 or 5 times. I de-installed and then
> re-installed everything...and the same thing happened. Any ideas?
> Thanks,
> Nora Barry
> www.druidmedia.com/index_sub.html <http://www.druidmedia.com/index_sub.html>
