[AG-TECH] ANL bridges require authentication???
Gurcharan S. Khanna
Gurcharan.S.Khanna at Dartmouth.EDU
Mon Mar 15 20:34:30 CST 2004
hi,
can the bridges be accessed without authentication? in other words, can one
simply run vic/rat from the command line with an IP and port number, or is vtc
with an embedded password (from the old AG 1.x or AG 2.x with certificates
required to access the bridged ANL venues?
thanks,
-gurcharan
--- You wrote:
Right, the bridges appear to not be integrating with the updated TVS properly.
I'm looking into this, and will send mail again when the problem is resolved.
As far as usage, you're right: the 'Use Unicast' option is available depending
on the presence of bridges in the venue. When you select it, you'll be
prompted to choose a particular bridge, and then the media tools will restart
pointed at the bridge addresses instead of the multicast addresses.
Tom
--- end of quote ---
Gurcharan S. Khanna
Associate Director
Research Computing
Dartmouth College
tele: 603-646-1644
http://research.dartmouth.edu
http://www.dartmouth.edu/~gkhanna
