[AG-TECH] Quickbridge request?
Thomas D. Uram
turam at mcs.anl.gov
Mon Mar 15 15:07:38 CST 2004
Right, the bridges appear to not be integrating with the updated TVS
properly. I'm looking into this, and will send mail again when the
problem is resolved.
As far as usage, you're right: the 'Use Unicast' option is available
depending on the presence of bridges in the venue. When you select it,
you'll be prompted to choose a particular bridge, and then the media
tools will restart pointed at the bridge addresses instead of the
multicast addresses.
Tom
Michael J. E. Swift wrote:
>--- "Thomas D. Uram" wrote:
>ANL is running a bridge in the test room. You can use it for your testing. If you have any problems with the bridge, let me know.
>--- end of quote ---
>Hi. I'm currently running the AG 2.1.2 client to connect to the Test room, but I'm having some difficulties with the Multicast/Unicast option. Our multicast is currently down, so when I saw there was a bridge running in the Test room, I figured I'd give it a try using the new client. However, the Unicast option is grayed out. It is sometimes grayed out and sometimes not, so does the program try to probe the venue to see if a bridge is running and available to use? Also, by choosing "Use Multicast" or "Use Unicast", does that actually switch the protocols for you? I tried switching between them last week and my vic and rat showed the multicast IP. Any help would be appreciated.
> Mike Swift
