[AG-TECH] Windows XP audio feedback
Allan Spale
aspale at evl.uic.edu
Thu Mar 11 11:20:28 CST 2004
Bob,
There's another thing to be careful of that I have encountered in the past
(but this may have just been a local problem at one point awhile back). I
have noticed in the past that sometimes when RAT restarts it automatically
unmutes the line out causing the same stuff to occur. Someone came up
with a better solution that avoids muting/unuting...simply push the fader
down all the way for that particular output and you do not have to worry
about it anymore.
Allan
Research Assistant
EVL @ UIC
On Thu, 11 Mar 2004, Robert Olson wrote:
> This makes me (and the next door office if I happen to have the laptop
> plugged into my speakers) crazy!
> What you probably need to do is go to the playback mixer panel and mute the
> microphone. You likely have an AC97-standard codec, and in that standard,
> the mute controls control the mic->line out path, which is causing the
> feedback.
> --bob
> At 09:17 AM 3/11/2004, Don Morton wrote:
> >This isn't specifically an AG/rat question, but
> >it's quite applicable and I have to think that
> >others have run into this.
> >Using a Windows XP laptop, when I plug in a
> >microphone, the sound going into the mic
> >comes out instantly on the speakers, naturally
> >resulting in horrible feedback. This occurs
> >with no application such as rat running, and
> >obviously, when I "do" run rat, it makes speaker
> >usage impossible, forcing me to headsets.
> >I'm wondering if this is due to a cheap audio card
> >in the laptop - best I can tell from system information
> >is that it's "SoundMAX Digital Audio" on a Sony laptop.
> >Has anybody else encountered and resolved such an issue?
> >I've played with every possible volume control provided
> >by XP, but don't seem to be able to stop my mic audio
> >from feeding through directly to the speakers (unless,
> >of course, I turn down the speaker or mic levels, which
> >defeats the purpose!).
> > Don Morton http://www.cs.umt.edu/~morton/
> > Department of Computer Science The University of Montana
> > Missoula, MT 59812 | Voice (406) 243-4975 | Fax (406) 243-5139
> >May your trails be crooked, winding, lonesome, dangerous, leading to the
> >most amazing view. May your mountains rise into and above the clouds.
> >-Edward Abbey, naturalist and author (1927-1989)
