[AG-TECH] Windows XP audio feedback
Osland, CD (Chris)
C.D.Osland at rl.ac.uk
Thu Mar 11 09:45:11 CST 2004
The mixer panel determines what is going to the (analogue) output,
I guess. For those looking for the panel, amongst numerous ways
of getting to it there is
Start -> Control Panel -> Sounds & Audio Devices
go to the Volume tab, then select Advanced
in the Device volume bordered region
(as opposed to Advanced in the Speaker settings bordered region!).
Cheers
Chris
____________________________________________________________________
Chris Osland Office tel: +44
(0) 1235 446565
Digital Media and Access Grid Medialab tel: +44 (0)
1235 446459
BIT Department Access Grid room tel: +44
(0) 1235 445666
e-mail: C.D.Osland at rl.ac.uk Fax: +44
(0) 1235 445597
CLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and are for the use of the
intended recipient only.
If you are not the intended recipient do not take any action on it or show
it to anyone else,
but return this email to the sender and delete your copy of it.]
> -----Original Message-----
> From: Don Morton [mailto:Don.Morton at umontana.edu]
> Sent: 11 March 2004 15:36
> To: Robert Olson; Sergeant A. G. Tech
> Subject: Re: [AG-TECH] Windows XP audio feedback
> On Thu, 11 Mar 2004 09:25:51 -0600, "Robert Olson" <olson at mcs.anl.gov>
> said:
> > This makes me (and the next door office if I happen to have
> the laptop
> > plugged into my speakers) crazy!
> > What you probably need to do is go to the playback mixer
> panel and mute
> > the
> > microphone. You likely have an AC97-standard codec, and in
> that standard,
> > the mute controls control the mic->line out path, which is
> causing the
> > feedback.
> Well, Bob, you're my hero for today! I looked at that mute
> control and
> figured, well duh, if I mute it, my mic ain't going to work,
> but indeed
> it does! Thanks, problem solved!!
> Don Morton http://www.cs.umt.edu/~morton/
> Department of Computer Science The University of Montana
> Missoula, MT 59812 | Voice (406) 243-4975 | Fax (406) 243-5139
> May your trails be crooked, winding, lonesome, dangerous,
> leading to the
> most amazing view. May your mountains rise into and above the clouds.
> -Edward Abbey, naturalist and author (1927-1989)
