[AG-TECH] Service Manager Error
Thomas D. Uram
turam at mcs.anl.gov
Wed Apr 7 11:41:40 CDT 2004
If this is across multiple machines, you should:
* check that the time is set properly on both machines, preferably
to an ntp server
* that you are using hostnames that resolve properly; can you ping
the node service machine from the service manager machine, and
vice-versa?
Beyond that, you can send your agns.log from the node service machine
and agsm.log from the service manager machine (from ~/.AccessGrid on
Linux, C:\Documents and Settings\<YOU>\ApplicationData\AccessGrid on
Windows), and I'll take a look at the problem.
Tom
Todd Reed wrote:
>I just downloaded and installed the AG Toolkit and I'm trying to configure the service manager. I've got the service manager created, but when I try to add a VideoConsumerService I get an error message "Exception: Error adding service: Exception: AGServiceManager.AddService failed: Unknown Reason" Any suggestions? I get the same message when I try to add any of the three options.
>--Todd
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040407/3647e792/attachment.htm>
