[AG-TECH] AG2.1.1 and RH 9
Michael Miller
mimiller at ncsa.uiuc.edu
Tue Sep 9 11:38:28 CDT 2003
Todd,
When I searched for "openssl096b-0.9.6b-3.i386.rpm", I didn't find
anything. And given my lack of experience with RH linux 9 and the number
of openssl packages to choose from, I want to make sure I install the right
one. Can you clarify which package you installed?
thanx
Michael Miller
NCSA
At 11:08 AM 9/9/2003, Todd Zimmerman wrote:
>Hi Chris,
>We currently have a couple of AG2.1.1 installs on RH9 and everything appears
>to be working fine. In fact we are currently testing a VenueServer and
>BridgeServer on RH9 and that also appears to be ok.
>The only issue I had was the pyOpenSSL issues. AG2.1.1 required libssl.so.2
>and libcrypto.so.2 which are provided in the openssl096b-0.9.6b-3.i386.rpm
>available at rpmfind.net. Once that is installed, I just ran the install
>script and all seemed to ge good.
>Todd
>Research Assistant - NewMIC
>New Media Innovation Centre
>Ph: 604.806.5100
>todd.zimmerman at newmic.com
> > -----Original Message-----
> > From: Osland, CD (Chris) [mailto:C.D.Osland at rl.ac.uk]
> > Sent: Tuesday, September 09, 2003 3:17 AM
> > To: ag-tech at mcs.anl.gov
> > Subject: [AG-TECH] AG2.1.1 and RH 9
> > As an "I second that" can I ask the list whether they think that
> > RedHat 9.0 is a suitable base for AG 2.x.x?
> > Our systems people have suggested that by the end of this year the
> > only supported RedHat may be RH 9, so we have just installed that
> > on the capture and audio machines, prior to installing AG 2.x.x .
> > Indications from elsewhere are that some bits of the system, possibly
> > just the servers, are unhappy with anything later than RH 7.3 .
> > Before expending the effort on installing AG 2.x.x, I would therefore
> > like to check which base people think is best (RedHat only, please).
> > In a similar vein, our current display machine is Windows 2000, and
> > I am assuming that it is sensible to move to Windows XP for AG 2.x.x;
> > any views on this?
> > BTW, we are doing the migrations by having alternate caddied hard
> > drives for the different systems, keeping the rest of the hardware
> > the same.
> > Cheers, and thanks in advance
> > Chris
> > ____________________________________________________________________
> > Chris Osland Office tel: +44 (0) 1235 446565
> > Digital Media and Access Grid Medialab tel: +44 (0) 1235 446459
> > BIT Department Access Grid room tel: +44 (0) 1235 445666
> > e-mail: C.D.Osland at rl.ac.uk Fax: +44 (0) 1235 445597
> > CLRC Rutherford Appleton Laboratory (Bldg. R18)
> > Chilton, DIDCOT, Oxon OX11 0QX, UK
> > [The contents of this email are confidential and
> > are for the use of the intended recipient only.
> > If you are not the intended recipient do not take
> > any action on it or show it to anyone else,
> > but return this email to the sender and delete your copy of it.]
Thanx,
Michael Miller
System Engineer
Visualization Technology Support
Computing and Data Management
National Center for Supercomputing Applications
University of Illinois - UC
217-649-0747
"If you're clear in your vision and trust the people in your team with
clear objectives, they will invariably do their best to achieve everything
desired, and usually deliver everything you could have hoped for and even
more." -Paul Debevec
