[AG-TECH] AG2.1.1 and RH 9
Todd Zimmerman
todd.zimmerman at newmic.com
Tue Sep 9 11:08:11 CDT 2003
Hi Chris,
We currently have a couple of AG2.1.1 installs on RH9 and everything appears
to be working fine. In fact we are currently testing a VenueServer and
BridgeServer on RH9 and that also appears to be ok.
The only issue I had was the pyOpenSSL issues. AG2.1.1 required libssl.so.2
and libcrypto.so.2 which are provided in the openssl096b-0.9.6b-3.i386.rpm
available at rpmfind.net. Once that is installed, I just ran the install
script and all seemed to ge good.
Todd
Research Assistant - NewMIC
New Media Innovation Centre
Ph: 604.806.5100
> -----Original Message-----
> From: Osland, CD (Chris) [mailto:C.D.Osland at rl.ac.uk]
> Sent: Tuesday, September 09, 2003 3:17 AM
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] AG2.1.1 and RH 9
> As an "I second that" can I ask the list whether they think that
> RedHat 9.0 is a suitable base for AG 2.x.x?
> Our systems people have suggested that by the end of this year the
> only supported RedHat may be RH 9, so we have just installed that
> on the capture and audio machines, prior to installing AG 2.x.x .
> Indications from elsewhere are that some bits of the system, possibly
> just the servers, are unhappy with anything later than RH 7.3 .
> Before expending the effort on installing AG 2.x.x, I would therefore
> like to check which base people think is best (RedHat only, please).
> In a similar vein, our current display machine is Windows 2000, and
> I am assuming that it is sensible to move to Windows XP for AG 2.x.x;
> any views on this?
> BTW, we are doing the migrations by having alternate caddied hard
> drives for the different systems, keeping the rest of the hardware
> the same.
> Cheers, and thanks in advance
> Chris
> ____________________________________________________________________
> Chris Osland Office tel: +44 (0) 1235 446565
> Digital Media and Access Grid Medialab tel: +44 (0) 1235 446459
> BIT Department Access Grid room tel: +44 (0) 1235 445666
> e-mail: C.D.Osland at rl.ac.uk Fax: +44 (0) 1235 445597
> CLRC Rutherford Appleton Laboratory (Bldg. R18)
> Chilton, DIDCOT, Oxon OX11 0QX, UK
> [The contents of this email are confidential and
> are for the use of the intended recipient only.
> If you are not the intended recipient do not take
> any action on it or show it to anyone else,
> but return this email to the sender and delete your copy of it.]
