[AG-TECH] Testing multicast connectivity...
Mitch Kutzko
mitch at ncsa.uiuc.edu
Tue May 20 21:43:10 CDT 2003
Hi, folks -- I'd say it's still a little friendly-user, but nobody's
complained of any problems so far.
It's at:
http://dast.nlanr.net/Projects/Beacon/Releases/beaconclient_v0.64_java.tar.gz
There's a precompiled binary you can use, or you can compile the source
that's included.
Once you get the clients swapped to the patched version, your Beacon should
start showing up on the ANL BeaconServer page.
Thanks, and please let me know if you have any questions!
Mitch
At 09:24 PM 5/20/2003 -0500, Bill Nickless wrote:
> Ah, this is a different problem. I thought you were talking about the
> beacon traffic not being heard by other beacons. Now I understand you're
> talking about your beacon crashing from time to time (or one of the three
> threads).
> Mitch Kutzko <mitch at ncsa.uiuc.edu> has a slightly modified version of the
> beacon code, with larger pre-compiled constant buffers. I'm not sure if
> Mitch thinks it's ready for prime time yet. I've copied him on this
> note--Mitch, is it ready for distribution?
> At 05:12 PM 5/20/2003 -0600, Richard Coffey wrote:
> >Hi Bill,
> >Avtwo.cs.utah.edu is the beacon is question. Every once and a while, Java
> >throws and exception and kills the connection. Thoughts on that?
> >-Richard
> >On 5/20/03 4:15 PM, "Bill Nickless" <nickless at mcs.anl.gov> wrote:
> > > This is consistent with an old bug in Cisco IOS prior to 12.0(10).
If the
> > > router directly connected to the source is running an earlier
version, then
> > > the behavior you mention below is possible.
> > > What specific beacon sources are you referring to?
> > > At 03:57 PM 5/20/2003 -0600, Richard Coffey wrote:
> > >> Hi all,
> > >> As of late, I've noticed problems with individual multicast addresses
> > >> working. The beaconserver's address seems to indicate that we cannot
send,
> > >> yet I've gone into the test room and successfully collaborated. Also,
> > people
> > >> cannot see me in a particular room, but in other rooms they can, and
vice
> > >> versa.
> > >> We're not running tight ACL's on our routers, so it's not that.
Thoughts?
> > >> -Richard
> > >> Richard C., SCI Evangelist
> > >> SCI Institute
> > >> University of Utah
> > >> http://www.sci.utah.edu/
> > >> 801.918.5050
> > >> 801.585.6513 fax
> > > Bill Nickless http://www.mcs.anl.gov/people/nickless +1 630 252
> > 7390
> > > PGP:0E 0F 16 80 C5 B1 69 52 E1 44 1A A5 0E 1B 74
> > F7 nickless at mcs.anl.gov
> Bill Nickless http://www.mcs.anl.gov/people/nickless +1 630 252 7390
> PGP:0E 0F 16 80 C5 B1 69 52 E1 44 1A A5 0E 1B 74 F7 nickless at mcs.anl.gov
Mitch Kutzko | mitch at dast.nlanr.net | mitch at ncsa.uiuc.edu | 217-333-1199
http://hobbes.ncsa.uiuc.edu/
