[AG-TECH] Testing multicast connectivity...
Bill Nickless
nickless at mcs.anl.gov
Tue May 20 21:24:55 CDT 2003
Ah, this is a different problem. I thought you were talking about the
beacon traffic not being heard by other beacons. Now I understand you're
talking about your beacon crashing from time to time (or one of the three
threads).
Mitch Kutzko <mitch at ncsa.uiuc.edu> has a slightly modified version of the
beacon code, with larger pre-compiled constant buffers. I'm not sure if
Mitch thinks it's ready for prime time yet. I've copied him on this
note--Mitch, is it ready for distribution?
At 05:12 PM 5/20/2003 -0600, Richard Coffey wrote:
>Hi Bill,
>Avtwo.cs.utah.edu is the beacon is question. Every once and a while, Java
>throws and exception and kills the connection. Thoughts on that?
>-Richard
>On 5/20/03 4:15 PM, "Bill Nickless" <nickless at mcs.anl.gov> wrote:
> > This is consistent with an old bug in Cisco IOS prior to 12.0(10). If the
> > router directly connected to the source is running an earlier version, then
> > the behavior you mention below is possible.
> > What specific beacon sources are you referring to?
> > At 03:57 PM 5/20/2003 -0600, Richard Coffey wrote:
> >> Hi all,
> >> As of late, I've noticed problems with individual multicast addresses
> >> working. The beaconserver's address seems to indicate that we cannot send,
> >> yet I've gone into the test room and successfully collaborated. Also,
> people
> >> cannot see me in a particular room, but in other rooms they can, and vice
> >> versa.
> >> We're not running tight ACL's on our routers, so it's not that. Thoughts?
> >> -Richard
> >> Richard C., SCI Evangelist
> >> SCI Institute
> >> University of Utah
> >> http://www.sci.utah.edu/
> >> 801.918.5050
> >> 801.585.6513 fax
> > Bill Nickless http://www.mcs.anl.gov/people/nickless +1 630 252
> 7390
> > PGP:0E 0F 16 80 C5 B1 69 52 E1 44 1A A5 0E 1B 74
> F7 nickless at mcs.anl.gov
Bill Nickless http://www.mcs.anl.gov/people/nickless +1 630 252 7390
PGP:0E 0F 16 80 C5 B1 69 52 E1 44 1A A5 0E 1B 74 F7 nickless at mcs.anl.gov
