[AG-TECH] AG 2.0 and Globus 2.2.x
Ti Leggett
leggett at mcs.anl.gov
Tue Feb 25 14:56:58 CST 2003
On Tue, 2003-02-25 at 14:46, Randy Groves wrote:
> So the main conflict will be the setting of GLOBUS_LOCATION, which in
> Globus is usually set in the user's startup files, right? The other
Correct.
> implication of your note is that if you are only installing AG2.0, you
> don't need to set GLOBUS_LOCATION in your startup files - correct?
Correct.
> -randy
> At 02:28 PM 2/25/2003 -0600, Ti Leggett wrote:
> >You should yes, make note that our rpms create an /etc/profile.d script
> >so that it set GLOBUS_LOCATION to where the rpms are installed.
> >On Tue, 2003-02-25 at 14:21, Randy Groves wrote:
> > > Since the two default install locations are different, it seems that they
> > > should be able to co-exist. Is this a valid assumption? I'd like to
> > > install an AG2.0 test on a machine presently running Globus 2.2.4.
> > > -randy
