[AG-TECH] AG 2.0 and Globus 2.2.x
Randy Groves
randy.groves at boeing.com
Tue Feb 25 14:46:48 CST 2003
So the main conflict will be the setting of GLOBUS_LOCATION, which in
Globus is usually set in the user's startup files, right? The other
implication of your note is that if you are only installing AG2.0, you
don't need to set GLOBUS_LOCATION in your startup files - correct?
-randy
At 02:28 PM 2/25/2003 -0600, Ti Leggett wrote:
>You should yes, make note that our rpms create an /etc/profile.d script
>so that it set GLOBUS_LOCATION to where the rpms are installed.
>On Tue, 2003-02-25 at 14:21, Randy Groves wrote:
> > Since the two default install locations are different, it seems that they
> > should be able to co-exist. Is this a valid assumption? I'd like to
> > install an AG2.0 test on a machine presently running Globus 2.2.4.
> > -randy
