[AG-TECH] VV Server Installation
Luc Renambot
renambot at cs.vu.nl
Wed Mar 13 14:58:44 CST 2002
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> Behalf Of Randy Groves
> Sent: Wednesday, March 13, 2002 21:14
> To: AG Technical Developers (E-mail)
> Subject: Re: [AG-TECH] VV Server Installation
> Exactly the problem that I experienced when I tried 7.2. The specific
> solution for the first problem is to remove the '/bin/noshell' from the
> 'nobody' entry in the /etc/passwd file.
What I did too. I'm not sure if it's really secure ??
> The place where I got stuck with 7.2 was when I tried to actually use the
> venue on the web. I got an error which indicated that there was
> a problem
> logging into the PostgreSQL database. That's where I stopped, and backed
> out to 7.1. I was SO close ...
A solution I found for that one is to allow TCP connection to
postmaster (PostgreSQL server), otherwise it only accepts
local connection. Perhaps it comes from a mis-configuration
of my machine. Again, I'm sure it's very secure, since
everybody could try to access the server (if I understand
correctly only a local connection from the http server is
required).
So the patch, in /etc/rc.d/init.d/postgresql, line 135,
I added "-o '-i'" to the /usr/bin/pg_ctl command:
su -l postgres -s /bin/sh -c "/usr/bin/pg_ctl -o '-i' -D $PGDATA
-p /usr/bin/postmaster start > /dev/null 2>&1" < /dev/null
cheers,
Luc.
