[AG-TECH] VV Server Installation
Randy Groves
randy.groves at boeing.com
Wed Mar 13 14:13:41 CST 2002
Exactly the problem that I experienced when I tried 7.2. The specific
solution for the first problem is to remove the '/bin/noshell' from the
'nobody' entry in the /etc/passwd file. For the second - I believe that
this is a result of the moo not starting up correctly. Once you've
verified that vv-moo is running, the second problem will go away. I am at
home right now and don't have my notes, but I seem to remember that the
startup script for the vv-moo sends all the errors to /dev/null, so it may
look like the moo starts, but it hasn't actually started.
The place where I got stuck with 7.2 was when I tried to actually use the
venue on the web. I got an error which indicated that there was a problem
logging into the PostgreSQL database. That's where I stopped, and backed
out to 7.1. I was SO close ...
-randy
At 09:44 AM 3/13/2002 -0600, Robert Olson wrote:
>>I installed RedHat 7.2
>I think this is the problem; RH made some changes in account things that
>cause problem with the VV stuff. Try backing off to 7.1 and see if it helps.
>--bob
