[AG-TECH] Problem Troubleshooting Audio
George Estes
gestes at ncsa.uiuc.edu
Mon Jul 9 09:18:41 CDT 2001
Corbin,
The Open Sound web page gives instructions for fixing the OSS cannot
load problem you describe (www.opensound.com). We are using the analog
Match Maker so I'm not sure about the noise problem, but the Digital Match
Maker may be over driven. Try lowering the levels all around in small
increments. Over-modulated audio in the digital domain can be ugly.
George
At 07:52 AM 7/9/2001 -0600, Stewart, Corbin J wrote:
>Greetings,
>I've been having some difficulty troubleshooting an audio problem with our
>node and would appreciate any suggestions or insights.
>Our node has been working perfectly up until about a week ago when a buzz
>started eminating from the speakers. The problem has escalated to popping
>and hissing when any noises are made in the room. The physical connections
>appear to be intact and we believe we have traced the cause to our Digital
>Match Maker. Is this a required piece of equipment? We suspect that it may
>be inducing noise.
>Also, when rebooting the Linux audio machine I get an error message stating
>that OSS cannot be loaded because a sound module has already been loaded
>into the kernel (es1371.o, Ensonique Sound). Oddly enough, no software or
>hardware configurations have been changed since the original working setup.
>Is this something I should be concerned about?
>I didn't perform the original installation and configuration so I'm kinda
>working in the dark.
>Thanks in advance,
>Corbin Stewart
>Videoconferencing & Collaborative Environments
>Sandia National Laboratories California
>(925) 294-4856
