Projection Surfaces
Jennifer Teig von Hoffman
jtvh at bu.edu
Wed Oct 25 11:43:19 CDT 2000
FWIW, BU uses a rear-projection screen, and it makes a real difference in
the quality of the image (and of the user-experience, since people can
walk across the screen and stuff without disrupting images). When we were
projecting against the wall (perhaps the cheapest imaginable projection
surface?) we could function okay, but some image detail seemed to get
lost.
So. . . issues regarding screen selection are probably broader than just
output merging (which we don't do here, though we do have our projectors
lined up reasonably well).
- Jennifer
On Wed, 25 Oct 2000, Don Morton wrote:
> Howdy, as we get in the process of ordering equipment, etc., I'm still
> considering what to use for a projection surface. I'm not clear
> on whether it's important to be able to "merge" the output
> from 2 or 3 projectors into a single image. If that's not an
> important issue, couldn't we just get away with 3 small, CHEAP screens,
> one for each projector?
> I don't think I've seen an example of "merged" projections, though I
> recall at ANL, there might have been an attempt at that.
> Thanks, Don
> Don Morton http://www.cs.umt.edu/u/morton/
> Department of Computer Science The University of Montana
> Missoula, MT 59812 | Voice (406) 243-4975 | Fax (406) 243-5139
