[AG-DEV] Re: Java Client for AG Server
Luis Galárraga
lgalarra at fiec.espol.edu.ec
Wed Apr 9 10:04:46 CDT 2008
Andrew and Thomas:
I did not imagine that a custom soap messaging implementation would be
necessary for that issue (in fact I thought we were omitting something
important when trying with the other implementations). Doing it by ourselves
would take several weeks of unplanned investigation and development, so
thanks a lot for your really valuable help. We will just wait for your
answer.
Luis,
2008/4/9, Andrew Rowley <Andrew.Rowley at manchester.ac.uk>:
> Hi,
> This was actually about the PHP SOAP interface (which also didn't work
> with the toolkit code), but the ideas are similar. Basically, I had to
> adapt what was there to produce the correct SOAP messages.
> Andrew :)
> Andrew G D Rowley
> Senior Development Officer
> Research Computing Services
> The University of Manchester
> Kilburn Building, Oxford Road
> Manchester, M13 9PL
> t : +44 (0) 161 275 0685
> e : Andrew.Rowley at manchester.ac.uk
> w : www.manchester.ac.uk/researchcomputing
> -----Original Message-----
> From: owner-ag-dev at mcs.anl.gov [mailto:owner-ag-dev at mcs.anl.gov] On Behalf
> Of Thomas D. Uram
> Sent: 09 April 2008 00:21
> To: Luis Galárraga
> Cc: ag-dev at mcs.anl.gov; openasel-commits at proyectossw.espol.edu.ec; Marisol
> Villacrés; Ing. Verónica Macías
> Subject: [AG-DEV] Re: Java Client for AG Server
> Hi Luis:
> Some information from Andrew Rowley, one of the developers of Portal AG,
> about Java SOAP interfaces to the AG3 components is in this mail to
> ag-dev in 2006:
> http://www.mcs.anl.gov/web-mail-archive/lists/ag-dev/2006/10/msg00007.html
> I hope this helps,
> Tom
> On 4/8/08 6:11 PM, Luis Galárraga wrote:
> > AG developers:
> > As I exposed in other posts in this channel, a group of developers of
> > our project are working in making tests which consist in invoking
> > methods of VenueServer interface through SOAP and Java. All of our
> > tests with Java have been unsuccessful until now, however when using
> > ZSI to construct a client, we could easily make remote invocations in
> > our server. So my question is for people who is working in or knows
> > about Portal AccessGrid project, as part of its design includes a Java
> > Servlet which communicates with AG Server through SOAP. Which tool are
> > you using for that task?? I have tested with Axis and XFire with no
> > success (in the first case, I get a confusing error message when
> > making the remote call, with the second one, I could not generate the
> > proxy classes). Could you help me with more hints about that issue?
> > Thanks in advance,
> > Luis Galárraga
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20080409/699271d2/attachment.htm>
