[AG-DEV] Re: Java Client for AG Server
Andrew Rowley
Andrew.Rowley at manchester.ac.uk
Wed Apr 9 03:52:33 CDT 2008
This was actually about the PHP SOAP interface (which also didn't work with the toolkit code), but the ideas are similar. Basically, I had to adapt what was there to produce the correct SOAP messages.
Andrew :)
Andrew G D Rowley
Senior Development Officer
Research Computing Services
The University of Manchester
Kilburn Building, Oxford Road
Manchester, M13 9PL
t : +44 (0) 161 275 0685
e : Andrew.Rowley at manchester.ac.uk
w : www.manchester.ac.uk/researchcomputing
-----Original Message-----
From: owner-ag-dev at mcs.anl.gov [mailto:owner-ag-dev at mcs.anl.gov] On Behalf Of Thomas D. Uram
Sent: 09 April 2008 00:21
To: Luis Galárraga
Cc: ag-dev at mcs.anl.gov; openasel-commits at proyectossw.espol.edu.ec; Marisol Villacrés; Ing. Verónica Macías
Subject: [AG-DEV] Re: Java Client for AG Server
Hi Luis:
Some information from Andrew Rowley, one of the developers of Portal AG,
about Java SOAP interfaces to the AG3 components is in this mail to
ag-dev in 2006:
http://www.mcs.anl.gov/web-mail-archive/lists/ag-dev/2006/10/msg00007.html
I hope this helps,
Tom
On 4/8/08 6:11 PM, Luis Galárraga wrote:
> AG developers:
> As I exposed in other posts in this channel, a group of developers of
> our project are working in making tests which consist in invoking
> methods of VenueServer interface through SOAP and Java. All of our
> tests with Java have been unsuccessful until now, however when using
> ZSI to construct a client, we could easily make remote invocations in
> our server. So my question is for people who is working in or knows
> about Portal AccessGrid project, as part of its design includes a Java
> Servlet which communicates with AG Server through SOAP. Which tool are
> you using for that task?? I have tested with Axis and XFire with no
> success (in the first case, I get a confusing error message when
> making the remote call, with the second one, I could not generate the
> proxy classes). Could you help me with more hints about that issue?
> Thanks in advance,
> Luis Galárraga
