Programmer's Manual - Draft
Susanne Lefvert
lefvert at mcs.anl.gov
Wed May 5 09:12:10 CDT 2004
I didn't want to commit before I got some feedback. However, if you want
it in CVS I can add it.
Susanne
On Tue, 4 May 2004, Thomas D. Uram wrote:
> I don't see this in cvs yet. Did I miss it? Or is it not yet there?
> Tom
> Susanne Lefvert wrote:
> >Here is a draft document of a programmer's manual for shared
> >applications. The information and code examples are reflecting current
> >CVS code that will be available in the next release. It would be great if
> >you could read it through and give comments, both on document and new
> >design.
> >Design Issues:
> >- Authorization.
> >The authorization mechanism used for shared applications right now are
> >based on a client's private ID. Should we instead use the same
> >authorization as the rest of the toolkit (certificates etc)?
> >To have a consisten interface, I added private ID to all SOAP methods of
> >the application service. Please, let me know if there are specific cases
> >where we need methods without the private ID authorization.
> >- Heart beats.
> >Currently, if the application service goes down, clients are not notified
> >they got disconnected. Also, if a client would crash for some reason,
> >the service can not tell the client is dead. Would it be a good idea to
> >introduce a heart beat mechanism, similar to the one existing in Venues,
> >for shared applications?
> >- Client Profile
> >When the Venue Client has been refactored to use a client ID, the client
> >profile argument will be replaced with that ID.
> >- Open vs. Join
> >I changed the standard command for application sessions to Join instead of
> >Open. I think it makes more sense to say join an applicatin session, in
> >the manual and the user interface, instead of open.
> >Any feed back would be appreciated.
> >Susanne
