Programmer's Manual - Draft
Thomas D. Uram
turam at mcs.anl.gov
Tue May 4 19:14:28 CDT 2004
I don't see this in cvs yet. Did I miss it? Or is it not yet there?
Tom
Susanne Lefvert wrote:
>Here is a draft document of a programmer's manual for shared
>applications. The information and code examples are reflecting current
>CVS code that will be available in the next release. It would be great if
>you could read it through and give comments, both on document and new
>design.
>Design Issues:
>- Authorization.
>The authorization mechanism used for shared applications right now are
>based on a client's private ID. Should we instead use the same
>authorization as the rest of the toolkit (certificates etc)?
>To have a consisten interface, I added private ID to all SOAP methods of
>the application service. Please, let me know if there are specific cases
>where we need methods without the private ID authorization.
>- Heart beats.
>Currently, if the application service goes down, clients are not notified
>they got disconnected. Also, if a client would crash for some reason,
>the service can not tell the client is dead. Would it be a good idea to
>introduce a heart beat mechanism, similar to the one existing in Venues,
>for shared applications?
>- Client Profile
>When the Venue Client has been refactored to use a client ID, the client
>profile argument will be replaced with that ID.
>- Open vs. Join
>I changed the standard command for application sessions to Join instead of
>Open. I think it makes more sense to say join an applicatin session, in
>the manual and the user interface, instead of open.
>Any feed back would be appreciated.
>Susanne
