New VenueClientUI module...
Thomas D. Uram
turam at mcs.anl.gov
Fri Jul 16 15:49:44 CDT 2004
Worked for me on Linux, with no noticeable difference in appearance.
The only problem I noticed in my short use of it was the following:
Traceback (most recent call last):
File "/usr/lib/python2.2/site-packages/wxPython/wx.py", line 1706, in
<lambda>
lambda event: event.callable(*event.args, **event.kw) )
File "/home/turam/dev/AccessGrid/AccessGrid/VenueClientUI2.py", line
586, in __CleanUp
self.venueListPanel.CleanUp()
2410, in CleanUp
self.list.CleanUp()
2463, in CleanUp
self.parent.__Layout()
AttributeError: VenueListPanel instance has no attribute
'_VenueList__Layout'
Tom
Justin Binns wrote:
> I've re-worked the VenueClientUI to use sizers instead of the
> wxLayoutAlgorithm stuff. I'd really appreciate folks testing it under
> Linux and Windows so we can see how it looks in those environments (with
> any luck at all, it will 'just work'). Anyway, the new module is
> 'AccessGrid/VenueClientUI2.py' and switching to it is easy - just modify
> 'bin/VenueClient.py' by replacing the line:
> from AccessGrid.VenueClientUI import VenueClientUI
> to the line:
> from AccessGrid.VenueClientUI2 import VenueClientUI
> That should do it. Let me know how it works (or doesn't).
> Justin
