VenueClient restructure
Eric Olson eolson at mcs.anl.gov
Wed Jun 25 13:50:39 CDT 2003
Susanne raised some good questions.  To the doc, I added purpose,
pros/cons, and a sequence diagram (sequence is mostly differences -- not
as detailed as the one in the VenueClient doc).  I included Susanne's
pros and cons from her e-mail and added my own.  I kept changing the
pros/cons, so I thought I would just send others will have more ideas.
I also did some search and replacing in the code and ended up with a quick
implemenation to make sure I wasn't missing something in the design.
Eric
On Tue, 24 Jun 2003, Susanne Lefvert wrote:
> I've been thinking about inheritance and not inheritance between
> bin.VenueClient and AccessGrid.VenueClient and would like to argue for
> inheritance :) If we remove inheritance, both classes will have to have an
> instance of the other class.  Events will be received by AccessGrid.VenueClient, which
> have to call bin.VenueClient and a button event will be received in
> bin.VenueClient that will call AccessGrid.VenueClient.  If we remove
> inheritance, both classes must have callback methods for the other
> class to use.  If we then add a new client (non ui based or something
> else), it will have to implement all callback methods instead of just
> overriding necessary methods from AccessGrid.VenueClient.
> It would be nice to add a section to the document that gives motivation
> to the suggested design changes.  And maybe more sequence diagrams to
> make it clearer (what we have now compared to how we want to change it).
> Susanne
> On Mon, 23 Jun 2003, Eric Olson wrote:
> > Here is a short (one page) description/overview of VenueClient
> > restructuring.
> > Comments are welcome -- if you know of specific areas that should be
> > addressed in more detail, please let me know.
> > Thanks,
> > Eric
Type: application/msword
Desc:
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20030625/b47abbe6/attachment.doc>
More information about the ag-dev mailing list
