proposal for common configuration elements for ITAPS services
Tim Tautges
tautges at mcs.anl.gov
Tue Sep 21 08:41:34 CDT 2010
On 09/20/2010 10:52 PM, Mark Miller wrote:
> Resending with an additional issue...
> In a recent email, the following issues were raised which I think add to
> this discussion...
> A. Standardization of autoconf support for MPI. --with-mpi is one
> way to handle it. CC=mpicc is another.
As a general note, I don't think the CC= solution will be an acceptable substitute for --with-mpi; that would require
the configure script to parse the contents of CC, and would be ambiguous e.g. if only CC were input and not CXX and F77/FC.
> B. Does --enable-imeshp imply --enable-imesh? If so, are there
> other cases of implied dependency between ITAPS interfaces we
> need to consider/address?
> C. Should the default for --enable-i<whatever> for all implementations
> be a) the same and b) ON by default. So, you have to specify
> --disable-i<whatever> or --enable-i<whatever>=no to explicitly turn
> it off? I'd argue yes, the default should be ON.
I would strongly resist imposing requirements on the default of these options, I don't think we should bind
implementations that way.
- tim
> Mark
> On Fri, 2010-09-10 at 07:54, Carl Ollivier-Gooch wrote:
>> So returning to this subject (as per Karen's request), I have two
>> suggestions:
>> 1. For -implementations-, which need to know at configure time whether
>> to build support for an interface, I propose we use:
>> --enable-imesh
>> --enable-imeshp
>> --enable-igeom
>> --enable-irel
>> --enable-ifield
>> Currently: of four implementations, we have --enable-imesh,
>> --enable-iMesh, --enable-itaps, --enable-tsttm (the ref implementation
>> needs no flag here, for obvious reasons). Lower case seems preferred
>> (and is typical for configure options). And imesh is definitely the
>> right thing to append (he says, despite currently using something else).
>> Unless someone has strenuous objections, we should standardize to
>> this, ideally before the next buildapolooza in a week and a half.
>> 2. For services and applications, which "only" need to know where to
>> find some include and link info, I find Jason's argument in favor of
>> using autoconf environment variables compelling, especially the part
>> about being able to build multiple components more easily. What do
>> other people think about adopting this as a standard for all our services?
>> Carl
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the tstt-interface
