iMesh telecon: closure and adjacency
Carl Ollivier-Gooch
cfog at mech.ubc.ca
Wed Sep 8 11:29:52 CDT 2010
On 09/08/2010 12:53 AM, James Porter wrote:
> On Tue, 2010-09-07 at 12:18 -0700, Carl Ollivier-Gooch wrote:
>> One issue that was raised (more or less as an aside while talking about
>> iMesh compliance) is whether an entity should be considered adjacent to
>> itself. The spec currently says that it is not, for first adjacencies.
>> Also, the spec says that a second adjacency call should not return the
>> originating entity, even if it otherwise would.
> In my experience, I've never found it useful to exclude an entity from
> its adjacency list. While I understand the reasoning that "adjacent"
> implies "not myself", it always just makes things harder for me. For
> example, if I wanted to get all the information necessary to (re)create
> a set of entities, I could use iMesh_getAdjEntIndices to get all the
> entities plus the vertices that comprise them. However, this fails if
> the set contains vertices too. I'm not sure if it's MOAB-specific or
> not, but (as I recall) trying this even returns an error, so I don't get
> *any* useful data.
If MOAB is returning an error here, it shouldn't. This is defined
implicitly by the behavior written into the unit tests, which expect (as
we decided a couple of years ago) consistent adjacency calls to do no
worse than silently return no data*; alas, we don't have definitive docs
on error returns. If the set contains vertices and you ask every entity
for the indices of adjacent vertices, the non-vertices should return
what you expect, and the vertices should return empty sub-lists. I
don't see how this makes it hard for you to replicate the contents of
the set. What info are you going to be missing here? If you're worried
about having an isolated vertex (one with no upward-adjacent entities in
the set), then you can iterate over vertices in the set to be sure you
get them all copied.
* The requested type and topology are required to be consistent; if they
aren't, the implementation is expected to return an error code of
BAD_TYPE_AND_TOPOLOGY. (Ditto for inconsistent requests to create an
iterator.) We discussed last week whether this consistency requirement
is a good thing. Jason argued that if an app asks for a particular
topology (i.e., not iMesh_ALL_TOPOLOGIES) then the type should be
ignored. The spec currently says that the type and topology must be
consistent (or one of them must be a wildcard). Personally, I don't see
any reason to change this behavior: even if the caller is being passed a
topology and isn't sure what it might be, using iBase_ALL_TYPES for the
type makes the call consistent. Are there possible scenarios in which
this might require different coding in a service/app? Yes, but that's
true for every decision in the API.
> At the very least, I think getting the adjacent vertices to a vertex
> should just return an empty list instead of returning an error. There's
> nothing so fundamentally "wrong" about returning same-dimension
> adjacencies that it should return an error, in my opinion.
Not returning an error is the behavior that's currently expected: asking
a face for adjacent faces (for instance) is supposed to silently return
an empty list. For array calls, that entity will return an empty
sublist, even though others will produce non-empty sublists.
Overall, I guess I'm not seeing a real problem that needs solving here.
(And if there isn't, then we should take advantage of an opportunity
to leave the syntax and semantics of the API alone.) Am I overlooking
something in the above?
Carl
Dr. Carl Ollivier-Gooch, P.Eng. Voice: +1-604-822-1854
Professor Fax: +1-604-822-2403
Department of Mechanical Engineering email: cfog at mech.ubc.ca
University of British Columbia http://www.mech.ubc.ca/~cfog
Vancouver, BC V6T 1Z4 http://tetra.mech.ubc.ca/ANSLab/
More information about the tstt-interface
