iRel.h interface update [was iRel proposal: removing non-one-to-one relation functions]
Mark Shephard
shephard at scorec.rpi.edu
Thu Oct 28 15:10:57 CDT 2010
On 10/28/10 3:59 PM, James Porter wrote:
> On Thu, 2010-10-28 at 03:12 -0400, seol at scorec.rpi.edu wrote:
>> From what we discussed in the bootcamp, the way of removing the relation (use case: removing classification) is still
>> missing. Mark B. proposed to add iRel_removeXXXXRelation.
> Sounds reasonable, though for consistency with tags/sets, I guess it'd
> be iRel_rmv(XYZ)Relation.
>>> * (RPI) Change iRel_newRel -> iRel_create (likewise for dtor -> destroy)
>>> Not much sense in doing this until iMesh/iGeom do it.
>> If I am not mistaken, this issue has been ratified (conclusion: YES)
> Ok, I have the notes from the meeting now, so I can start making the
> changes that I missed earlier.
>>> * (RPI) Missing iRel_get(Ent|Set)SetArrRelation
>>> I'm arguing against all functions like this anyway, so I left them out
>>> until we decide on that to do there.
>> To the best of my remembrance, we agreed to add iRel_getEntSetArr and iRel_getSetSetArr in the bootcamp.
> In the notes, it says that the decision was that we'd remove
> iRel_set(Ent|Set)SetArrRelation (note that this is "set" not "get").
>>> * (RPI) Missing switch_order from iRel_setEntEntRelation and friends
>>> This argument isn't necessary to make these functions work. If people
>>> really see a use for them, we can add them, but it wasn't obvious to
>>> me that this was the way to go. This would need discussion, I think.
>> Among 24 iRel_set/get functions, the eight functions don't have switch_order argument to determine the "relation side".
>> Incompleteness could be interpreted in either of two: "relation side" was accidentally missed from the eight functions
>> or the necessity of "relation side" is not clear yet. If neither is the case, let's discuss.
> The reason I didn't add switch_order to those, and presumably the reason
> that they weren't there before is that one can set a one-to-one relation
> without bothering to define the order. That is, there are both
> iRel_setEntSetRelation and iRel_setSetEntRelation, whereas there's no
> iRel_setEntArrEntRelation (but there is the reverse).
> This assumes that an explicit call to a set relation function implies
> that the relation is symmetric. Even with "Both"-type relations, I don't
> think this is a problem, but that would require a pretty long
> digression, so I'm avoiding it for now.
>> In addition to the above, I propose some wordsmithing idea:
>> 1. change "int *ierr" to "int *err" for consistency with other interface
> Sounds reasonable.
>> I checked iMesh and iRel. Most of iMesh/iRel functions do have "int *err" at the end of arg list, but some (not
>> many) don't. Do we have any conventions for the order of args?
> If you're talking about what I think you're talking about, this is due
> to the calling conventions of Fortran functions, where string length for
> an arg is appended to the end of the function parameter list. (I think.)
> If you want this to change, you'll have to convince everyone that
> wrappers are the way to go for Fortran support (you won't find any
> arguments from me).
>> 3. We defined the enumeration type "RelationType". To represent "relation type", we use "integer" type instead of
>> "RelationType". Here I see two options:
>> #1. change "int ent_or_set" to "RelationType type"
>> #2. remove the enumeration type "RelationType" since it's no use
> The ITAPS interfaces use ints instead of enums to maintain ABI
> compatibility since the size of an enum is not defined by the standard*.
> Whether this is important or not is a different question, though. (I for
> one doubt the necessity of this.)
> * Ok, technically the size of an int isn't defined either beyond minimum
> ranges, but at least ints are generally guaranteed to be the same size
> on a given platform.
>> 4. adding "EntArr" to "Relation Type" and removing iRel_getEntSetIter& iRel_getEntArrSetIterArr
>> CURRENT Relation Type: Ent, Set, Both (Ent&Set)
>> NEW: Ent, Set, Both (Ent&Set), EntArr
> Assuming we end up agreeing that directly encoding one-to-many
> relationships in iRel (instead of relying on iMesh/iGeom to give us this
> though sets and/or iterators), I don't think this is a good way to go
> about doing it as it's really just a hack to work around implementations
> that don't support sets. A clearer and more general-purpose way to do
> this would be to add another property representing the cardinality of
> the relation, that is, one-to-one, one-to-many, and so on.
> Don't take the above suggestion as endorsement, though. As the
> maintainer of (currently) the only iRel implementation, I should note
> that doing this (either your way or mine) will significantly increase
> the complexity and decrease the potential for interoperability** of iRel
> unless the iMesh and iGeom specs are updated as well. In Lasso's case
> anyway, doing this interoperably would require variable-length tags (and
> possibly a way of serializing other implementations' handles).
Note as the specification is it is not interoperable with ITAPS
implementations that are being used to support DOE applications.
> I've discussed some of these options before with Tim Tautges, and what
> you're proposing is not a small change by any means. It may require
> rethinking large portions of the iRel specification (e.g. asymmetry),
> which may not be entirely bad, as the draft specification is more than a
> bit sparse in some areas. (I'm sure people have ideas about how they
> think it should work, but it would be good to ensure we're all on the
> same page here.)
Considering that the iRel specification at this point came from one
place with in essence, no input for others that have implementations, it
is a reasonable thing to be careful and if we need to modify things so
relationships are support for all of ITAPS.
> ** Between different implementations of ITAPS interfaces
>> This avails non set-dominant impementation to support "iRel" effectively without interfering set-dominant
>> implementation and not against neither of "interchangeability" and "interoperability".
> I must confess that my knowledge of other ITAPS implementations is
> limited, but are you suggesting that a) you wouldn't support the
> set-based functions in iRel at all, or b) that you'd support them, but
> they wouldn't be the optimal way of working with data in your
> implementation?
We support all the set functions. However, controlling everything by
sets becomes quite computationally intensive when you are doing lots of
local mesh modification, which is exactly what users of out
implementations are doing. Thus although we support sets, the
applications we support typically use sets in specific ways that cause
no complexity with the sets that are in place.
> If we're talking about (a) here, this is a pretty optimistic view,
> perhaps overly so. Clearly, if one implementation supports a given
> function and the other does not (e.g. a "set-dominant" interface doesn't
> fully support arrays or an "array-dominant" interface doesn't support
> sets), that function is by definition not interchangeable. For
> MOAB/CGM/Lasso, this problem is academic, since MOAB and CGM support
> both set- and array-based operation (and Lasso will too, however it ends
> up looking), but for other implementations, this could be more serious
> issue. In practice, this would mean that you'd be unable to use many of
> the tools we write that target ITAPS interfaces.
> If we're talking about (b), see my discussion above on relation
> cardinality.
> - Jim
More information about the tstt-interface
