iRel proposal: removing non-one-to-one relation functions
fabien delalondre
delalf at scorec.rpi.edu
Tue Oct 26 12:44:38 CDT 2010
> I haven't seen any responses to this. I'm hoping this is because no one
> has a problem with it. I'll give it a few more days for comments, but if
> no one pipes up, I'll make the proposed changes.
> - Jim
> On Mon, 2010-10-04 at 14:55 -0500, James Porter wrote:
>> Currently in iRel, there are a handful of functions to get/set relations
>> that aren't one-to-one (e.g. iRel_getEntEntArrRelation). It's my
>> understanding that these are only meant to work in, say, Entity<->Set
>> relations, and that the entity array returned is the contents of the set
>> related to the entity on the left side. That is, it's equivalent to
>> calling iRel_getEntSetRelation and then i(Mesh|Geom)_getEntities on the
>> set you get back.
>> I propose that these functions be removed. Here's why:
>> Note 1: most of this is based on my discussion with Tim Tautges and our
>> implementation, Lasso, so hopefully I'm not just misinterpreting the
>> spec.
>> Note 2: I use "left-" and "right-" prefixes to denote which side of the
>> relation an entity or set is on.
>> 1) Problems with setting relations
>> The biggest problem with these functions is in setting relations. What
>> you're actually doing is updating the contents of the related set to
>> contain those new elements. That is, if left-ent A is related to
>> right-set B, setting a relation between A and [C,D,...,Z] (where C-Z are
>> right-ents) actually inserts C-Z into B. That's certainly not what I'd
>> expect initially; I would expect iRel to only affect stuff in its own
>> area (e.g. relation tags set on each interface). It gets worse because
>> it's not clear what you should do when the set B doesn't exist (throw an
>> error? create a new set? Lasso does the former, currently).
>> This also presents further problems because there's no corresponding
>> iRel_setEntSetArrRelation function, even though a set could be contained
>> in a set just as easily as an entity.
>> 2) Confusion about iRel's capabilities
>> iRel really creates one-to-one (possibly asymmetric) relations, but
>> these functions seem to imply that one-to-many or even many-to-many
>> relationships are possible. This is not, as far as I can tell, the
>> intention.
I believe that if I want to try to use iRel to simplify my iFields
implementation without having to define sets, I need to have a 1 to n
relationship (not sure about the m to n yet).
Fabien
>> 3) Not that useful
>> In most cases, these functions only save a single line of code. If
>> you're trying to be truly generic (i.e. you don't know what the set-side
>> interface is), it's a little more complicated, but not much.
>> 4) Hurts clarity of Python interfaces
>> This is a mostly selfish reason, since I'm the developers of the ITAPS
>> Python interfaces, but if all relation functions are one-to-one, I'm
>> able to simplify the Python iRel interface's functions to "getRelation"
>> and "setRelation", since I know a priori the type of element that should
>> be returned when you call getRelation.
>> - Jim
More information about the tstt-interface
