iRel proposal: removing non-one-to-one relation functions
Mark Miller
miller86 at llnl.gov
Thu Oct 7 10:34:50 CDT 2010
Hi All,
I wasn't sure but I don't think I saw a response to this. I am certainly
not as familiar enough with iRel as I should be so I don't think I can
make an informed response. Can anyone else?
On Mon, 2010-10-04 at 12:55, James Porter wrote:
> Currently in iRel, there are a handful of functions to get/set relations
> that aren't one-to-one (e.g. iRel_getEntEntArrRelation). It's my
> understanding that these are only meant to work in, say, Entity<->Set
> relations, and that the entity array returned is the contents of the set
> related to the entity on the left side. That is, it's equivalent to
> calling iRel_getEntSetRelation and then i(Mesh|Geom)_getEntities on the
> set you get back.
> I propose that these functions be removed. Here's why:
> Note 1: most of this is based on my discussion with Tim Tautges and our
> implementation, Lasso, so hopefully I'm not just misinterpreting the
> spec.
> Note 2: I use "left-" and "right-" prefixes to denote which side of the
> relation an entity or set is on.
> 1) Problems with setting relations
> The biggest problem with these functions is in setting relations. What
> you're actually doing is updating the contents of the related set to
> contain those new elements. That is, if left-ent A is related to
> right-set B, setting a relation between A and [C,D,...,Z] (where C-Z are
> right-ents) actually inserts C-Z into B. That's certainly not what I'd
> expect initially; I would expect iRel to only affect stuff in its own
> area (e.g. relation tags set on each interface). It gets worse because
> it's not clear what you should do when the set B doesn't exist (throw an
> error? create a new set? Lasso does the former, currently).
> This also presents further problems because there's no corresponding
> iRel_setEntSetArrRelation function, even though a set could be contained
> in a set just as easily as an entity.
> 2) Confusion about iRel's capabilities
> iRel really creates one-to-one (possibly asymmetric) relations, but
> these functions seem to imply that one-to-many or even many-to-many
> relationships are possible. This is not, as far as I can tell, the
> intention.
> 3) Not that useful
> In most cases, these functions only save a single line of code. If
> you're trying to be truly generic (i.e. you don't know what the set-side
> interface is), it's a little more complicated, but not much.
> 4) Hurts clarity of Python interfaces
> This is a mostly selfish reason, since I'm the developers of the ITAPS
> Python interfaces, but if all relation functions are one-to-one, I'm
> able to simplify the Python iRel interface's functions to "getRelation"
> and "setRelation", since I know a priori the type of element that should
> be returned when you call getRelation.
> - Jim
Mark C. Miller, Lawrence Livermore National Laboratory
================!!LLNL BUSINESS ONLY!!================
miller86 at llnl.gov urgent: miller86 at pager.llnl.gov
T:8-6 (925)-423-5901 M/W/Th:7-12,2-7 (530)-753-8511
More information about the tstt-interface
