Proposal for Requiring Save/Restore of Sets and Tags
Mark Miller miller86 at llnl.gov
Tue Oct 5 08:15:12 CDT 2010
On Tue, 2010-10-05 at 04:41, Tim Tautges wrote:
> With the current definition of set parent/child relations, you can embed not only directed graphs in the data model, but
> also general graphs.  In this case you'd use only one of the parent/child types of links, and two nodes in the graph
> linked by an edge would each have a parent link to the other.  Granted you'd need to be careful when traversing these,
> because of the inherent cycles, but at least you'd be able to represent them, in a part of the data model that is
> already fairly natural for many of the other queries on graph nodes, and for representing other types of (i.e. directed)
> graphs.
> As to what you'd use them for, choose any application of undirected graphs on a mesh, e.g. maximal independent set,
> graph coloring, etc.
> I agree that embedding these types of graphs into a data model that seems more geared to directed graphs is a stretch.
> But, in my view, we should keep the possibility of embedding general graphs in the data model, even if accessing those
> types of graphs is somewhat unnatural.
If you want to make an argument for general graphs, then why are the
functions named 'Parent' and 'Child' -- which are much more suggestive
of a very specific kind of graph, a tree in fact? Why not just name
them...
iMesh_addGraphEdge();
iMesh_rmvGraphEdge();
iMesh_getGraphOutEdges();
iMesh_getGraphInEdges();
Also, in general graphs, we tend to want/need to be able to associate
data with vertices AND EDGEs of the graph. iMesh as designed can only do
the vertex part of that (e.g. tags on sets).
Next, I could be misunderstanding things but I don't think iMesh can
support the concept of multiple graphs purposed for different types of
traversals, can it (e.g. different collections of edges in the graph
used for different purposes).
Finally, if a dataset contains a graph, we can't really avoid reading
and instantiating that in the _load call and saving it in the _save call
even if its unlikely any other client is going to know what to do with
that data.
So, I think trying to make an argument general graphs, given the current
design, is dubious at best.
> - tim
> On 10/05/2010 12:56 AM, Carl Ollivier-Gooch wrote:
> > To get a cycle, you've got to have this looping back on itself.
> > Semantically, it makes sense, but it's (a) silly and (b) unlikely to
> > occur except on purpose, in which case, why bother?
> > Carl
Mark C. Miller, Lawrence Livermore National Laboratory
================!!LLNL BUSINESS ONLY!!================
miller86 at llnl.gov      urgent: miller86 at pager.llnl.gov
T:8-6 (925)-423-5901    M/W/Th:7-12,2-7 (530)-753-8511
More information about the tstt-interface mailing list
