Proposal for Requiring Save/Restore of Sets and Tags
Carl Ollivier-Gooch cfog at mech.ubc.ca
Tue Oct 5 00:56:51 CDT 2010
On 10/04/2010 09:29 PM, Mark Miller wrote:
> Hi Carl,
> I don't think I disagree with anything you've said.
> But, if the spec. says cycles are NOT allowed and an implementation
> supports that, I don't see how that is a problem.
> So, maybe the whole issue is mentioning the issue of cycles as
> prominently as they are in the proposal.
> Now, if the spec. says cycles ARE ALLOWED and an implementation does NOT
> support that, then that would be a problem.
Agreed, throughout.  But we probably should decide once and for all what
we intend about cycles (and put in the docs this time...).
> But, I think you are arguing that the spec. should NOT include cycles. I
> kinda agree with that as they really don't seem to make sense. The only
> use case I can think of is improper subsets where some implementation
> wants to be a little lazy about detecting outright equality between
> subsets where it might otherwise easily decide its ok to make one a
> subset of another.
To get a cycle, you've got to have this looping back on itself.
Semantically, it makes sense, but it's (a) silly and (b) unlikely to
occur except on purpose, in which case, why bother?
Carl
Dr. Carl Ollivier-Gooch, P.Eng.                   Voice: +1-604-822-1854
Professor                                           Fax: +1-604-822-2403
Department of Mechanical Engineering             email: cfog at mech.ubc.ca
University of British Columbia              http://www.mech.ubc.ca/~cfog
Vancouver, BC  V6T 1Z4                  http://tetra.mech.ubc.ca/ANSLab/
More information about the tstt-interface mailing list
