Proposal for Requiring Save/Restore of Sets and Tags
Jason Kraftcheck
kraftche at cae.wisc.edu
Mon Oct 4 12:51:36 CDT 2010
On 10/01/2010 02:59 PM, Carl Ollivier-Gooch wrote:
> On 09/29/2010 10:27 PM, Mark Miller wrote:
>> In choosing a file format, there are several complicating factors to
>> consider:
>> o Tags may be placed on entity sets as well as entities.
>> o Entity sets may contain entity sets as well as entities.
>> o The entity set containment graph may contain cycles.
>> o The entity set parent/child graph may contain cycles.
> I don't think it's particularly relevant to the way these things are
> likely to be stored, but I strongly disagree, semantically, with
> allowing cycles. Also, it's harder to implement these the infinite
> depth retrieval with cycles (not super hard, but harder).
> Containment can be interpreted as subset or member. Subsets clearly
> can't be cyclical (okay, you could have improper subsets in a cycle, but
> why?). Membership also doesn't make sense: set A contains B contains C
> contains A? Draw me that Venn diagram!
> Parent-child semantics also don't make sense cyclically: A is the parent
> of B is the parent of C is the parent of A?
> Finally, can anyone describe an actual use case for cycles?
IIRC, the last time the group discussed this, it was decided that we should
allow cycles. But even if we leave that as an implementation-defined
behavior, it is not relevant to this particular discussion. When storing
iMesh data in a persistent format: if the implementation allows cycles then
it should be prepared to save/load sets with cyclical relations.
- jason
More information about the tstt-interface
