another iMesh / fields issue we may want to consider.
Mark Shephard shephard at scorec.rpi.edu
Fri May 7 05:24:13 CDT 2010
At the boot camp there was extensive discussion on the issue of where
mesh shape information and coordinate information goes. There was
general consensus that if we were starting at square one all of this
would be in fields. However, because where iMesh is already, that what
"is in iMesh" will remain there, but that fields will be able to fully
support all mesh shape and coordinate information.
The item I wanted to mention here is that there was a couple of side
comments on the "higher order node stuff" including, if I recall
correctly, Tim asking if what we had defined could be revisited. With
all the other stuff we were discussing at the boot camp we did not go
any deeper into that and I was wondering if we should. I know that Carl
and Luo had worked pretty hard on getting something into iMesh for
higher order nodes that attempted to address the concerns of Tim and
SCOREC. However, I am not sure how much of that was implemented and/or
how happy people were with the compromise.
If the above is the situation with respect to this issue, the question I
would ask is as follows: Should we consider having iMesh support just
the coordinate information originally defined and have what we do in the
fields stuff deal with all the additional possibilities?
More information about the tstt-interface mailing list
