create/destroy name change proposal
Tim Tautges
tautges at mcs.anl.gov
Thu May 6 10:51:28 CDT 2010
Echoing previous comments, I think:
- it is worthwhile to adjust names for consistency, i.e. we should change:
. remove -> destroy
. new -> create (though I think the proper name should be iMesh_createMesh, not iMesh_create)
- I don't think we should add an iMesh_addTag, because of the ambiguities with getting tags whose values have not been
set (a comment in the header would be useful here, probably in the set function, to the effect that setting results in
adding too)
- I think we should allow apps to specialize on memory management, and the current API allows that well enough now
- tim
Jason Kraftcheck wrote:
> Mark Miller wrote:
>> Hi Mark,
>> I like yours and Carl's comments on this storage issue. However, I also
>> think that together you have arrived at what the specification should
>> say regarding storage associated with things being removed or deleted. I
>> think both you and Carl are saying that the whether storage is freed up
>> on remove/destroy operations is left to the implementation.
>> However, I also agree with your point that if iMesh_destroy (aka
>> iMesh_dtor) did that, we'd be in a heap of trouble. So, the
>> specification of iMesh_destroy should be that all memory associated with
>> the iMesh instance be freed.
>> But, now that I think about it, that raises another question having to
>> do with how the functions are named. I kinda sorta had in mind that any
>> operation with 'destroy' in the name also freed memory while 'remove'
>> did NOT say one way or the other.
> I agree with your first to paragraphs. Not so much with the later one. All
> this function renaming is for consistency seems a little excessive for me.
> While it would be nice to have consistent names, I just don't think it's
> worth the API breakage..
> But as long as we're discussing API changes and memory issues I'd like to
> bring up a different issue that has bothered me for a while: the status
> array passed back from iMesh_createEntArr. I have two issues with this: a)
> it is quite inconvenient and of dubious value and b) it is rather
> inconsistent from an API POV.
> What is the use case for this? How many applications will truly check the
> array to see which individual entity creations failed? Is it worth having
> every application remember to free this array as opposed to making that <1%
> of applications that care about per-entity success/failure do their entity
> creation one at a time? Why not just have a flag selecting, for
> implementations that do not allow duplicate entities, whether it should
> return the handle for the existing entity or fail for duplicate entities.
> As for b), I think that any function in the interface should free any arrays
> allocated during the call before returning failure. This is possible for
> every function in the API except iMesh_createEntArr, which is required to
> return an array when it fails.
> - jason
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the tstt-interface
