create/destroy name change proposal
Mark Miller miller86 at llnl.gov
Thu May 6 00:32:49 CDT 2010
Hi Mark,
I like yours and Carl's comments on this storage issue. However, I also
think that together you have arrived at what the specification should
say regarding storage associated with things being removed or deleted. I
think both you and Carl are saying that the whether storage is freed up
on remove/destroy operations is left to the implementation.
However, I also agree with your point that if iMesh_destroy (aka
iMesh_dtor) did that, we'd be in a heap of trouble. So, the
specification of iMesh_destroy should be that all memory associated with
the iMesh instance be freed.
But, now that I think about it, that raises another question having to
do with how the functions are named. I kinda sorta had in mind that any
operation with 'destroy' in the name also freed memory while 'remove'
did NOT say one way or the other.
On Wed, 2010-05-05 at 20:48, Mark Beall wrote:
> I'll second Carl's concerns related to this.
> If you dictate that an implementation must immediately release memory,
> you're likely to run into two issues:
> 1) significant performance degradation vs. an implementation that
> intelligently manages its memory (not necessarily vs. an
> implementation that does this badly).
> 2) memory fragmentation issues that can actually leave the application
> with less usable memory
> We have a way to run our code such that all memory allocations go
> through the system memory allocation calls with no management of the
> memory (this really just exists for testing things with various memory
> checking tools that don't catch things if you don't do that). If you
> turn that on, you get a hit in performance of about 30% (in using the
> mesh database for meshing, the actual performance of the low level
> functions is obviously much more). In addition, although we don't
> release all the memory we possibly could, you also see a memory usage
> increase of about 10% (system memory allocators generally have
> overhead, ours doesn't)
> There might be some reasonable things that could be specified, such as
> when a mesh is deleted that all memory associated with that mesh is
> returned to the application. Or, perhaps, that there is an API
> function that, when called, would request the release of all memory
> that can be (which is open to enough interpretation that any
> implementation should be happy with it - if they don't have the
> ability to release memory that's not being used, then it's a
> particularly simple function to write).
> It seems to me that this is more a "quality of implementation" issue
> that can't really be reasonably specified. If you're going to go in
> that direction, you probably also need to specify maximums for memory
> usage and minimum performance specs.
> mark
> On May 5, 2010, at 10:16 AM, Carl Ollivier-Gooch wrote:
> >> Related concern #1:
> >> What says the specification regarding what is supposed to happen to
> >> storage associated with the things being removed or destroy? I
> >> could not
> >> find anything that specifically enumerates what, if anything, an
> >> implementation is required to do with removing or destroying things
> >> with
> >> the storage associated with those things. If we give implementations
> >> flexibility what to do with storage, I could envision implementations
> >> where a remove operation just indicates internally that an item
> >> should
> >> be ignored but otherwise does nothing to free up any storage that
> >> might
> >> be associated with the item having been previously added. Likewise
> >> for
> >> 'destroy' operations. Worse, I could storage that is 'lost' to
> >> removed
> >> or destroy'd things being kept around presisting across save/load
> >> which
> >> would be even worse. So, I think the specification should speak to
> >> the
> >> issue of an implementation's responsibility regarding storage
> >> associated
> >> with things being removed/destroyed.
> > Can of worms warning! :-)
> > GRUMMP is one of the implementations that marks stuff as removed
> > without freeing up storage.  Rationale: entities are created
> > internally in blocks rather than one by one.  Removing an entity in
> > the middle of a block with compression of the remaining data is O(n)
> > for every deletion, which is bad.  Actually, it's worse, because
> > that changes all of your connectivity data (whether you use integers
> > or pointers).  And it's even worse than that, because the way GRUMMP
> > stores sets and entity handle tags is by using pointers to
> > entities.  So if I compress the data structures, all of that stuff
> > has to be updated.
> > As a result, the compression is done in batch and only occasionally.
> > This is why we have this obscure function about handle validity: to
> > give implementations notice that it's okay to rearrange the database
> > without messing up handles that the application may be holding on
> > to.  When the database is compressed, blocks of memory with no
> > entities in them are freed, but the remaining blocks won't be 100%
> > full (except by remarkable coincidence).
> > GRUMMP -does- compress the database before writing (actually, it
> > also reorders at this point, too).  So there's no carryover of non-
> > garbage-collected memory to the next run.
Mark C. Miller, Lawrence Livermore National Laboratory
================!!LLNL BUSINESS ONLY!!================
miller86 at llnl.gov      urgent: miller86 at pager.llnl.gov
T:8-6 (925)-423-5901     M/W/Th:7-12,2-7 (530)-753-851
More information about the tstt-interface mailing list
