Updated iRel.h with iterator support
Mark Beall
mbeall at simmetrix.com
Tue Feb 9 10:12:33 CST 2010
Tim,
On the question of can you get the set from an iterator - the
motivation for putting functions in iRel to get an iterator rather
than a set was to avoid the overhead associated with creating "fake
sets" for implementations that don't implement things as sets. Given
that, it probably doesn't make sense to be able to ask the iterator
for the set since that just reintroduces that issue.
I hope to have some more time today or tomorrow to take a closer look
at your changes.
mark
On Feb 5, 2010, at 11:09 AM, Tim Tautges wrote:
> Hi all,
> Attached is an updated header for iRel with iterator support.
> There's one very important assumption I'm making which I'm not sure
> is valid, and which I need input on: can one use an iterator to
> recover the set it's iterating? Currently I don't see such a
> function. The result is that very few iterator-based functions
> actually make sense for iRel, namely 2 of them:
> getEntSetIterRelation and getEntArrSetIterArrRelation.
> One other side effect of this change, and one which impacts both
> iGeom and iMesh, is that we need an iBase_EntityIterator type, which
> before now we didn't have. That shouldn't be a terribly difficult
> change for most implementations.
> And, just writing the signatures for these functions reminded me
> just how narrowly targeted these modifications are; for example,
> nowhere in our interfaces do we consider the notion of iterating
> over sets stored in a set. Thus, iterator-based functions in iRel
> will not be useful here. It's also not clear what the semantics are
> for creating an iterator over a set that contains sets. Does that
> iterator iterate the entities contained in any sets?
> You might ask who would ever want to do such a thing, but that's
> exactly the question we should avoid asking when designing interfaces.
> - tim
> "You will keep in perfect peace him whose mind is
> steadfast, because he trusts in you." Isaiah 26:3
> Tim Tautges Argonne National Laboratory
> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
> phone: (608) 263-8485 1500 Engineering Dr.
> fax: (608) 263-4499 Madison, WI 53706
> #ifndef __iRel_LASSO_HPP__
> #define __iRel_LASSO_HPP__
> #define IREL_MAJOR_VERSION 1
> #define IREL_MINOR_VERSION 0
> /** \mainpage The ITAPS Relations Interface iRel
> * Each ITAPS interface encapsulates functionality that "belongs"
> * together, for example mesh or geometric model functionality. In
> * some cases, however, data in several of these interfaces need to
> * be related together. For example, a collection of mesh faces
> * should be related to the geometric model face which they
> * discretize. The ITAPS Relations interface accomplishes this in a
> * way which allows the lower-level interfaces to remain
> * independent.
> * iRel defines relations as pairwise relations between entities
> * or entity sets. Related entities can be in the same or different
> * interfaces. A given relation is created for a given pair of
> * interfaces and returned in the form of a \em Relation \em Handle.
> * After a specific relation pair has been created, concrete
> * relations for that pair can be assigned and retrieved for
> * specific entities using set and get functions on the iRel
> * interface. A given interface instance can appear in one or many
> * relation pairs, each identified by the relation handle.
> * \section Relation Types
> * Relations are also distinguished by a pair of relation types.
> * For each interface in a relation pair, a corresponding type
> * indicates whether the relation applies to entities, entity sets,
> * or both entities and sets in the corresponding interface in the
> * pair. If only one of the interfaces in a given pair has a
> * 'both'-type, entities and entity sets in that
> * interface are each related to either entities or sets in the other
> * interface in the pair. If both of the sides of a relation are of
> * 'both'-type, entities and sets on one side of a relation point to
> * sets on the other side.
> * \section Argument Order
> * Many functions in the iRel interface take as input two entities,
> * or two lists of entities, along with a relation handle. For
> * these functions, the entities or lists are assumed to be in the
> * same order as the interfaces used to create that relation pair.
> * For example, if a relation pair is created by calling:
> * \code
> * iRel_createRelation(instance, iface1, ent_or_set1, type1,
> * iface2, ent_or_set2, type2,
> * &relation_handle, &ierr)
> * \endcode
> * and relations set by calling
> * \code
> * iRel_setEntEntRelation(instance, relation_handle,
> * ent1, is_set1, ent2, is_set2, &ierr)
> * \endcode
> * it is assumed that ent1 is contained in iface1 and ent2 in
> * iface2.
> * For functions taking only one entity or list as input, and
> * returning an entity or list, an additional argument indicates
> * whether the input entity or list belongs to the first or second
> * interface in that relation pair.
> #include "iGeom.h"
> #include "iMesh.h"
> #include "iRel_protos.h"
> #ifdef __cplusplus
> extern "C"
> #endif
> /**\brief Type used to store iRel interface handle
> * Type used to store iRel interface handle
> typedef void* iRel_Instance;
> /**\brief Type used to store references to relation pairs
> * Type used to store references to relation pairs
> typedef struct iRel_RelationHandle_Private* iRel_RelationHandle;
> /**\brief \enum IfaceType Enumerator specifying interface types
> * Enumerator specifying interface types. This enumeration is
> * necessary because functions to get entities of a given dimension
> * are part of the higher-level interfaces (e.g. iGeom, iMesh)
> instead
> * of iBase.
> enum IfaceType
> {iRel_IGEOM_IFACE = 0,
> iRel_IMESH_IFACE,
> iRel_IFIELD_IFACE,
> iRel_IREL_IFACE};
> /**\brief \enum RelationType Enumerator specifying relation types
> * Enumerator specifying relation types. A relation has two
> types, one
> * for each side of the relation.
> enum RelationType
> {iRel_ENTITY = 0,
> iRel_SET,
> iRel_BOTH};
> extern struct iBase_Error iRel_LAST_ERROR;
> /**\brief iRel_dtor Destroy the interface object
> * Calls destructor on interface object
> \param instance Interface object handle to destroy
> \param *ierr Pointer to error value, returned from function
> void iRel_dtor(iRel_Instance instance, int *ierr);
> /**\brief Create a relation pair between two interfaces
> * Creates a relation pair between two interfaces, passing
> * back a handle to the pair.
> \param instance Interface instance
> \param iface1 1st interface object in the relation pair
> \param ent_or_set1 This relation relates entities (=0) or
> sets (=1)
> or both (=2) from 1st interface object
> \param iface_type1 Type of 1st interface (0=iBase, 1=iGeom,
> 2=iMesh,
> 3=iField, 4=iRel)
> \param iface2 2nd interface object in the relation pair
> \param ent_or_set2 This relation relates entities (=0) or
> sets (=1)
> or both (=2) from 2nd interface object
> \param iface_type2 Type of 2nd interface (0=iBase, 1=iGeom,
> 2=iMesh,
> 3=iField, 4=iRel)
> \param *rel Pointer to relation handle, returned from function
> void iRel_createRelation (
> iBase_Instance iface1,
> const int ent_or_set1,
> const int iface_type1,
> iBase_Instance iface2,
> const int ent_or_set2,
> const int iface_type2,
> iRel_RelationHandle *rel,
> int *ierr);
> /**\brief Get information for this relation handle
> * Get information about the interfaces and relation type for this
> * relation. Relation type for each side is passed back as
> integers,
> * but values will be from RelationType enumeration.
> \param rel Handle of relation pair being queried
> \param *iface1 Side 1 instance for this relation
> \param *type1 Relation type for side 1 of this relation
> \param *iface2 Side 2 instance for this relation
> \param *type2 Relation type for side 2 of this relation
> void iRel_getRelationInfo (
> iRel_RelationHandle rel,
> iBase_Instance *iface1,
> int *type1,
> iBase_Instance *iface2,
> int *type2,
> int *ierr);
> /**\brief Destroy a relation pair
> * Destroy the relation pair corresponding to the handle input
> \param rel Handle of relation pair to destroy
> void iRel_destroyRelation (
> int *ierr);
> /**\brief Get interfaces related to specified interface
> * Get interfaces related to the specified interface
> \param iface Specified interface
> \param interfaces Pointer to array holding returned interfaces
> \param interfaces_allocated Pointer to allocated size of
> interfaces list
> \param interfaces_size Pointer to occupied size of interfaces
> list
> void iRel_getRelatedInterfaces (
> iBase_Instance iface,
> iBase_Instance **interfaces,
> int *interfaces_allocated,
> int *interfaces_size,
> int *ierr);
> /**\brief
> \param rel Relation handle being queried
> \param ent1 1st entity of relation being set
> \param ent2 2nd entity of relation being set
> void iRel_setEntEntRelation (
> iBase_EntityHandle ent1,
> iBase_EntityHandle ent2,
> int *ierr);
> void iRel_setEntSetRelation (
> iBase_EntitySetHandle entset2,
> int *ierr);
> void iRel_setSetEntRelation (
> iBase_EntitySetHandle entset1,
> int *ierr);
> void iRel_setSetSetRelation (
> int *ierr);
> /**\brief Set a relation between an entity and several entities
> * Set a relation between an entity and several entities. If
> either
> is a set and that side of the relation is 'both'-type, set
> relations
> for individual entities in that set too.
> \param switch_order If non-zero, ent1 is related with iface2
> and
> ent_array_2 with iface1 of
> specified relation, otherwise vica versa
> \param ent_array_2 Entity(ies) to be related to ent1
> \param num_entities Number of entities in ent_array_2
> void iRel_setEntEntArrRelation (
> int switch_order,
> iBase_EntityHandle *ent_array_2,
> int num_entities,
> int *ierr);
> void iRel_setSetEntArrRelation (
> int switch_order,
> int num_entities,
> int *ierr);
> void iRel_setEntSetArrRelation (
> int switch_order,
> iBase_EntitySetHandle *entset_array_2,
> int num_entities,
> int *ierr);
> void iRel_setSetSetArrRelation (
> int switch_order,
> int num_entities,
> int *ierr);
> /**\brief Set relations between arrays of entities pairwise,
> * ent_array_1[i]<->ent_array_2[i]
> * Set relations between arrays of entities pairwise,
> ent_array_1[i]<->ent_array_2[i]. If either array
> contains sets and that side of the relation is 'both'-type,
> set relations for individual entities in those sets too.
> \param ent_array_1 1st array of entities of relation being set
> \param num_ent1 Number of entities in 1st array
> \param ent_array_2 2nd array of entities of relation being set
> \param num_ent2 Number of entities in 2nd array
> void iRel_setEntArrEntArrRelation (
> iBase_EntityHandle *ent_array_1,
> int num_ent1,
> int num_ent2,
> int *ierr);
> void iRel_setEntArrSetArrRelation (
> int num_ent1,
> int num_ent2,
> int *ierr);
> void iRel_setSetArrSetArrRelation (
> iBase_EntitySetHandle *entset_array_1,
> int num_ent1,
> int num_ent2,
> int *ierr);
> /**\brief Get entity related to specified entity and relation
> handle
> * Get entity related to specified entity and relation handle.
> Also
> returns whether the related entity is an entity or a set.
> \param ent1 1st entity of relation being queried
> \param switch_order 1st entity is related to 1st interface
> (=0) or 2nd
> interface (=1) of relation pair
> \param *ent2 Pointer to entity related to ent1
> void iRel_getEntEntRelation (
> int switch_order,
> iBase_EntityHandle *ent2,
> int *ierr);
> void iRel_getEntSetRelation (
> int switch_order,
> iBase_EntitySetHandle *entset2,
> int *ierr);
> void iRel_getSetSetRelation (
> int switch_order,
> int *ierr);
> void iRel_getEntSetIterRelation (
> int switch_order,
> iBase_EntityIterator *entset2,
> int *ierr);
> /**\brief Get entities related to specified entity and relation
> * Get entities related to specified entity and relation; returns
> entity sets or contained entities, depending on relation type
> (entity, set, or both).
> \param switch_order ent1 is related with 1st (=0) or 2nd (=1)
> interface
> of this relation pair
> \param *ent_array_2 Pointer to array of entity handles
> \param *ent_array_2_allocated Pointer to allocated size of
> ent_array_2
> \param *ent_array_2_size Pointer to occupied size of
> ent_array_2
> void iRel_getEntEntArrRelation (
> int switch_order,
> iBase_EntityHandle **ent_array_2,
> int *ent_array_2_allocated,
> int *ent_array_2_size,
> int *ierr);
> void iRel_getSetEntArrRelation (
> int switch_order,
> int *ierr);
> /**\brief Get entities related to those in specified array and
> relation, pairwise
> * Get entities related to those in specified array and relation,
> pairwise.
> Returns sets or entities, depending on relation type and
> entities in
> ent_array_1.
> \param ent_array_1 Array of entities whose relations are
> being queried
> \param ent_array_1_size Number of entities in ent_array_1
> \param switch_order Entities in ent_array_1 are related with
> 1st (=0)
> or 2nd (=1) interface of this relation pair
> ent_array_2
> ent_array_2
> \param *offset Pointer to offset array; (*offset)[i] is index
> into
> (*ent_array_2) of 1st relation of ent_array_1[i]
> \param *offset_allocated Pointer to allocated size of offset
> \param *offset_size Pointer to occupied size of offset
> void iRel_getEntArrEntArrRelation (
> int ent_array_1_size,
> int switch_order,
> int **offset,
> int *offset_allocated,
> int *offset_size,
> int *ierr);
> void iRel_getEntArrSetArrRelation (
> int switch_order,
> iBase_EntitySetHandle **entset_array_2,
> int *ierr);
> void iRel_getSetArrSetArrRelation (
> int switch_order,
> int *ierr);
> void iRel_getEntArrSetIterArrRelation (
> int switch_order,
> iBase_EntityIterator **entiter,
> int *entiter_allocated,
> int *entiter_size,
> int *ierr);
> /**\brief Infer relations between entities in specified pair of
> interfaces
> * Infer relations between entities in specified pair of
> interfaces. The
> criteria used to infer these relations depends on the
> interfaces in
> the pair, the iRel implementation, and the source of the data
> in those
> interfaces.
> void iRel_inferAllRelations (
> int *ierr);
> /**\brief Infer relations and relation type between entities in
> specified
> * pair of interfaces
> interfaces, and the
> * relation type used by this iRel implementation. The
> * criteria used to infer these relations depends on the
> interfaces in
> * the pair, the iRel implementation, and the source of the data
> in those
> * interfaces.
> * \param instance Interface instance
> * \param rel Relation handle created by implementation
> * \param *ierr Pointer to error value, returned from function
> void iRel_inferAllRelationsAndType (
> int *ierr);
> /**\brief Infer relations corresponding to specified entity and
> relation pair
> * Infer relations corresponding to specified entity and relation
> pair. The
> interfaces in
> in those
> interfaces.
> \param entity Entity whose relations are being inferred
> \param is_set Entity is a regular entity (=0) or a set (=1)
> \param iface_no Entity corresponds to 1st (=0) or 2nd (=1)
> interface
> in relation pair
> void iRel_inferEntRelations (
> iBase_EntityHandle entity,
> int iface_no,
> int *ierr);
> void iRel_inferSetRelations (
> iBase_EntitySetHandle entity_set,
> int iface_no,
> int *ierr);
> /**\brief Infer relations corresponding to specified entities
> and relation pair
> * Infer relations corresponding to specified entities and
> relation pair. The
> interfaces in
> in those
> interfaces.
> \param entities Array of entities whose relation are being
> inferred
> \param entities_size Number of entities in array
> \param is_set Entities are regular entities (=0) or sets (=1)
> \param iface_no Entities correspond to 1st (=0) or 2nd (=1)
> interface
> in relation pair
> void iRel_inferEntArrRelations (
> iBase_EntityHandle *entities,
> int entities_size,
> int iface_no,
> int *ierr);
> void iRel_inferSetArrRelations (
> iBase_EntitySetHandle *entity_sets,
> int entities_size,
> int iface_no,
> int *ierr);
> /**\brief Create a new iRel instance
> * Create a new iRel instance. Currently no options are
> implemented.
> \param options Options for the implementation
> \param *instance Interface instance
> \param options_len Length of options string
> void iRel_newRel(const char *options,
> iRel_Instance *instance,
> int *ierr,
> const int options_len);
> #ifdef __cplusplus
> } /* extern "C" */
> #endif
> #endif /* #ifndef __iRel_LASSO_HPP__ */
More information about the tstt-interface
