iRel interface updates
Tim Tautges
tautges at mcs.anl.gov
Sun Aug 15 15:14:27 CDT 2010
On 08/14/2010 10:06 PM, seol at scorec.rpi.edu wrote:
> Tim,
> I put my questions below.
>> On 07/21/2010 05:31 PM, James Porter wrote:
>>> On Wed, 2010-07-21 at 18:08 -0400, seol at scorec.rpi.edu wrote:
>>>> - I think iBase_EntityIterator should be defined in iBase.
>>> That's reasonable. I think it should be defined in the same way as
>>> iBase_Instance (that is, as a void*) to minimize the amount of changes
>>> required for code that uses iMesh/iGeom. The other option would be to
>>> replace iMesh_EntityIterator with iBase_EntityIterator everywhere
>>> (likewise for iGeom).
>> I think the latter would be most appropriate, since the entity handle
>> types are all in iBase.
> Do we mean only changing the type to iBase_EntityIterator? It would be
> possible to provide iterator functions in iBase too; iBase_getNextEntIter,
> iBase_resetEntIter and iBase_endEntIter shared by all interfaces. (SCOREC
> iterator is implemented in this way so it can be shared by geom model,
> mesh model, geom entity set, and mesh entity set)
Only the type. The functions would have to remain interface-specific, since not all implementations use the same
iterator implementation for iMesh, iGeom and iRel. That's essentially the same reason we have getEntities or equivalent
in iGeom and iMesh.
>>>> - Any specific reasons for not having iRel_getEntSetArrRelation and
>>>> iRel_getSetSetArrRelation?
>>> I'm not sure if these make sense, but I haven't done much looking at the
>>> get/set relation code.
>> You can't currently relate a single entity/set to multiple sets, whereas
>> you can relate a single set to multiple
>> entities (indirectly, through a set-set relation).
> I see iRel_setEntSetArrRelation, iRel_setSetSetArrRelation in iRel.h.
> Aren't they for relating a single entity/set to multiple sets?
Yeah, that looks suspicious to me too. Jim, did you find that odd? Does anybody remember the rationale for those?
- tim
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the tstt-interface
