is_List removed?
seol at scorec.rpi.edu seol at scorec.rpi.edu
Sat Aug 14 21:17:57 CDT 2010
> Then, just to clarify, the list is an ordered set. This means that all
> calls made on a list return entities in the same order that they were
> added?
That's right.
> Any other differences?
When an item is added/removed multiple times, addition/removal occurs at
the end position of the list. Unlike an ordinary list, it supports set
boolean operations, set containment (subset, parent/child) and tag data
(arbitrary attachable data to the entity/set).
Seegyoung
> On Fri, Aug 13, 2010 at 2:57 PM, Tim Tautges <tautges at mcs.anl.gov> wrote:
>> Not to my knowledge, since list- and set-type sets are still supported.
>> - tim
>> On 08/13/2010 01:19 PM, Xiaolin Li wrote:
>>> Tim,
>>> Ryan told that is_List in iMesh has been removed? Could you confirm
>>> this? But it is still in the v8 version of the header file in the web.
>>> Xiaolin
>> "You will keep in perfect peace him whose mind is
>>  steadfast, because he trusts in you."               Isaiah 26:3
>>             Tim Tautges            Argonne National Laboratory
>>         (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>>         phone: (608) 263-8485      1500 Engineering Dr.
>>           fax: (608) 263-4499      Madison, WI 53706
> ~Ryan Kaufman
More information about the tstt-interface mailing list
