strange preprocessor stuff
seol at scorec.rpi.edu seol at scorec.rpi.edu
Wed Apr 21 12:03:52 CDT 2010
Those are fine with us too.
Seegyoung
> Those sound fine to me.
> - tim
> Carl Ollivier-Gooch wrote:
>> Jason Kraftcheck wrote:
>>> iBase.h, iMesh.h, and iGeom.h all appear to contain the following
>>> preprocessor statements:
>>>   #ifndef ITAPS
>>>   #define ITAPS
>>>   #endif
>>> This is a really generic name for a preprocessor variable.  It will
>>> have the
>>> side effect of stripping all instances of the token 'ITAPS' from any
>>> code
>>> that includes our headers.  One particularly case encountered by
>>> someone at
>>> UWisc was as follows:
>>>   The directory in which to search for a test file is specified to the
>>>     test code at compile time with a preprocessor macro: -DSRCDIR=...
>>>   The code does something like:
>>>     const char* input_file = STRINGIFY(SRCDIR) "/input.vtk";
>>> If the user has the source installed in a location such that one of the
>>> components of the path is 'ITAPS' (or in this case 'ITAPS-src'), then
>>> the
>>> preprocessor will remove the 'ITAPS' string from the path, causing the
>>> test
>>> to fail because it cannot load the input file.
>>> I cannot find anywhere where this preprocessor macro is used.  Does
>>> anyone
>>> know why we have this in the headers?  Can it be removed?  Or if not,
>>> can it
>>> be renamed to something like '_ITAPS_INTERFACE'?
>> The reason for having -something- like this -somewhere- is so that an
>> implementation can choose to compile things differently when it's not
>> using ITAPS.  Since my implementation does this, it's entirely possible
>> that I started the whole thing.  Changing the name to something sensible
>> would be a good idea, though.  Maybe _ITAPS_iBase, _ITAPS_iMesh, etc?
>> Carl
> "You will keep in perfect peace him whose mind is
>    steadfast, because he trusts in you."               Isaiah 26:3
>               Tim Tautges            Argonne National Laboratory
>           (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>           phone: (608) 263-8485      1500 Engineering Dr.
>             fax: (608) 263-4499      Madison, WI 53706
More information about the tstt-interface mailing list
