input files for iMesh_unitTest
Carl Ollivier-Gooch
cfog at mech.ubc.ca
Tue Oct 27 20:43:26 CDT 2009
Mark Miller wrote:
> Hi All,
> I may not recall correctly but in the past, I thought compliance test
> built and processed everything 'in memory' and did NOT need an input
> file.
> Now, current compliance tests won't run without an input file. But,
> assuming the test is written to be somewhat specific to the input data
> it is processing, I can't find the input file?
> Shouldn't the input file be in the repo, too?
In fact, the current iMesh compliance tests will run with any arbitrary
input file. Yes, this is something of a problem, in that all the tests
are effectively internal consistency tests on some level. The new
modular framework (whenever I have time and/or student power available
to get that coded) will require that an implementation have some way of
getting its internal state to match some legacy VTK file. This will
make it possible to test correctness of adjacency calls and vertex
coords, etc. Sets and tags are being (and will continue to be) tested
under the assumption that create/set/get tuples will exist.
Carl
Dr. Carl Ollivier-Gooch, P.Eng. Voice: +1-604-822-1854
Associate Professor Fax: +1-604-822-2403
Department of Mechanical Engineering email: cfog at mech.ubc.ca
University of British Columbia http://www.mech.ubc.ca/~cfog
Vancouver, BC V6T 1Z4 http://tetra.mech.ubc.ca/ANSLab/
More information about the tstt-interface
