Mesh set question
Carl Ollivier-Gooch
cfog at mech.ubc.ca
Mon Oct 26 20:54:21 CDT 2009
Tim Tautges wrote:
> Mark Shephard wrote:
>> Is there documentation on the rules for mesh sets under mesh
>> modification?
>> For example what happens in the following case:
>> 2-D mesh and I want to swap an edge between two mesh faces that are in
>> different mesh sets.
>> Which mesh set do the new faces go into, or do they not go into either
>> mesh set?
>> Mark
> The proper behavior under these circumstances is application-dependent.
> There are no rules right now governing what happens under mesh
> modification.
The problem is that the -application- may know the rules, but there's no
way it can let various -services- know what those rules are. And even
if we had a default definition that you can only modify within a set
(all "before" ents that will be changed are in the set, and all "after"
ents that are new are in that set, too), you still have the problem that
there's no way to find out what sets an entity is in to do the checks.
This basically gets us into a state where set membership has to be
maintained by applications, not by services --- and services may butcher
things rather badly. Or is there some reasonable way to do this that I
haven't thought of?
As Mark pointed out, this is the problem with having sets be general
sets rather than something mesh semantics. I'm not saying that there's
a reasonable collection of mesh semantics that covers the realistic use
cases, just pointing out that, without knowing what the set means, an
implementation or service has no hope of maintaining the set, even if
it's willing to pay a price for the entity->set info.
> Even more important (and I think you raised this issue recently too),
> what happens when entities get deleted is also currently undefined. In
> MOAB, sets can be created either as "tracking" or not; for tracking
> sets, deleted entities get removed, for non-tracking sets, they don't.
> This is under the philosophy of maximizing choice for applications; a
> tracking set imposes a cost of at least handle_size per entity per
> tracking set (could be more, if you're interested in the details feel
> free to ask.)
I currently check every set every time I delete an entity. That's
because I didn't envision the sorts of things Tim talks about, with
millions of sets. In that case, my run time blows up. But if those are
tracking sets, MOAB's memory blows up (and the runtime is also big), so
it's a potential problem either way.
The easiest solution, of course, is not to use iMesh sets at all. ;-)
Oh, and by the way: the same problems occur with classification, but
presumably iRel implementations will have two-way maps between (say)
mesh and geometry entities, so the search will at least be quick when
you need to delete an entity. (Assuming you have all iRel instance
handles available, which you can't really count on at present. We could
modify the spec to insist that iMesh and iGeom and i??? instances keep
track of all iRel instances that they're associated with, and then the
classification problem would be taken care of.)
Bottom line (IMO): we definitely didn't think through all the
consequences of mesh modification early enough, and now we've got a bit
of a mess.
> PS - this is yet another reason I think we need an option string on our
> set and tag creation functions. Other reasons include being able to
> specify sparse or dense on tag creation. If people are interested in
> that, I'd gladly write a proposal for an interface change.
While this is a problem that we may well conclude requires a solution
(rather than just ignoring it), I don't think an option string is the
right way to go. We presumably would have a small, finite number of
options that we can specify with booleans or enums. If different
implementations allow different option strings that turn on special
functionality unique to that implementation, then we lose
interoperability.
Yes, I know, this is potentially an issue for load and save as well, and
I wouldn't say no to getting rid of that option string, too: I know I
don't use it for anything I can't live without, and I'm sure no one else
would recognize the same option strings I do.
And, on that cheery note, I'm off for dinner.
Carl
Dr. Carl Ollivier-Gooch, P.Eng. Voice: +1-604-822-1854
Associate Professor Fax: +1-604-822-2403
Department of Mechanical Engineering email: cfog at mech.ubc.ca
University of British Columbia http://www.mech.ubc.ca/~cfog
Vancouver, BC V6T 1Z4 http://tetra.mech.ubc.ca/ANSLab/
More information about the tstt-interface
