Mesh set question
Tim Tautges
tautges at mcs.anl.gov
Mon Oct 26 10:37:38 CDT 2009
Mark Shephard wrote:
> Is there documentation on the rules for mesh sets under mesh modification?
> For example what happens in the following case:
> 2-D mesh and I want to swap an edge between two mesh faces that are in
> different mesh sets.
> Which mesh set do the new faces go into, or do they not go into either
> mesh set?
> Mark
The proper behavior under these circumstances is application-dependent. There are no rules right now governing what
happens under mesh modification.
Even more important (and I think you raised this issue recently too), what happens when entities get deleted is also
currently undefined. In MOAB, sets can be created either as "tracking" or not; for tracking sets, deleted entities get
removed, for non-tracking sets, they don't. This is under the philosophy of maximizing choice for applications; a
tracking set imposes a cost of at least handle_size per entity per tracking set (could be more, if you're interested in
the details feel free to ask.)
- tim
PS - this is yet another reason I think we need an option string on our set and tag creation functions. Other reasons
include being able to specify sparse or dense on tag creation. If people are interested in that, I'd gladly write a
proposal for an interface change.
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the tstt-interface
