My notes from the discussion at the bootcamp
Lori A. Diachin diachin2 at llnl.gov
Mon Oct 19 14:00:58 CDT 2009
Hi All,
Here are my notes from the discussion at the bootcamp regarding fields and
software processes..
Lori
Notes from Fields discussion
Issues
  - Units/dimensions
  - coordinate fields
  - fields on subsets of a mesh
  - basis/distribution functions (specify order and form)
  - change of basis
  - analytic fields
  - integral/differential constraints
  - memory management
  - mesh/field/operator relationship
  - mapping domain to range
  - parallelism
  - operations of fields (iField or a service)
  - intrinsic/extrinsic data
  - vectors/tensors/coordinate systems
  - level of interoperability
  - implementation as tags
  - usability in linear solvers
  - splitting coupled problems/composit fields
  - known relations among fields - derived fields is an issue to consider
  - capturing experimental data
Use Cases/Requirements
  - Mesh to mesh transfer (includes changing basis - e.g., FEM to FVM, see
below)
   - local evaluation of distribution functions - forward and reverse
   - distribution functions are written in some coordinate system
   - local integration and differentiation
   - may need to extrapolate to a point outside the mesh
   - may need to do some evaluation off processor
   - integral and differential constraints
  - Local change of basis
   - assumes the mesh is the same
   - want to take advantage of this to do truly local operations
  - Multiple representations of the same field
   - e.g. simulation data, experimental data, etc
   - domain may have multiple realizations
   - call these multiple 'instances' of the same field
   - same physical quantity - will have some common characteristics
     such as dimension
   - there will be a hierarchy of data - some high level representation
     information will be inherited downward
  - Interactions with solvers/preconditioners
   - need to deal with multiple tensors in a "composed" field
      - e.g., velocity, pressure, energy, etc.
      - need to recognize that different rules may apply to different
        components
      - application may want the ability to set the order
  - Interactions with post-processing tools
   - Derived quantities are common
     - Should think about how to support operations on fields (eg div,
grad, +, *)
   - Need to know domain, intrinsic/extrinsic - should include this in set of
     characteristics of a field
   - memory management - selective load of a field to visualize only it -
     don't load everything
   - time series must be captured
     - more generally need to deal with relationships among fields, nested
       subspaces, snapshots of the same field, parameter series, etc
        - useful for uncertainty quantification as well
  - Fundamental operations (manipulation of fields)
   - pointwise evaluations (smart - take advantage of knowledge that is known)
   - convolution, norms, algebra
   - coordinate conversions (e.g, coordinate to polar)
   - unit conversions (e.g, meters to inches) - low on the priority list?
   - given a point, get the parametric coordinates associated with it (reverse)
      - for searches it would be nice to have the following information
        - it's in the element, it's in the neighborhood, no idea where it is
   - initialize, save, re-initialize (assignment),
      - load for principle field components (minimal set such that you can
        reconstruct the other data from it) - application specific
   - bounds over collections of sets
   - integration over sets
   - conversion between precisions (double to single, etc)
   - mapping fields from lower to higher dimensional data
   - projections/slicing, etc from higher to lower dimensional data
  - Differential operators
   - order of operations is important
   - if there are multiple ways to do this - provide this as service; not
     part of the interface
  - Need to support analytic functions
Would like to capture the basic operations that allow us to do most of
the services - what are these canonical operations and data that we
need to know about the field?
Scope of fields interface
Field Representation
  - Units/dimensions
  - memory management
  - what data types do we need - float, double? int? byte? boolean?
  - can we use tags?
Data Model
Definition: Note that there is a high level description of a field
that is somewhat abstract - call this a "field template".  A
particular instance that is derived from the field template and
associated with a specific domain is called the "field".
Field templates are associated with a domain template (e.g. a
space/time domain) and specific domain is a discretization of the
abstract domain
The domain "has a" coordinate field (special, priviledged field)
Construction operations
  - create
  - load
     - given a string, instantiate or read from file
     - separate header information from other data
     - read coefficients separately from header and other instances?
     - read distribution function information if non-standard (app must
support)?
  - save
  - set
     - Distribution function coefficients (specify a value for it)
     - Distribution functions (common ones we all support through keywords?,
         more sophisticated through other mechanisms - callbacks?)
        - includes specific characterization of interpolation scheme
          (e.g. at what points are the dofs defined?  vertices, mid-edges,
          bezier points?)
        - optional, but very commmonly used, distribution function association
          with mesh entity type
        - may need call backs for advanced functions - e.g. analytic functions
        - abstract domain that the field is defined on - optional (want to
carry
          it if you have it)
     - units (measurement: furlong/fortnight^squared, part of field
              dimensional analysis: (length/time^squared), part of field
template)
        - make it easy to do standards
     - precision
     - dimension
     - tensor order
     - data type
     - unique name
     - isCoordField ?  does this need to be special
  - get all of the above
     - get field instance by name or some other identifier
     - get all the fields
  - associate the distribution functions with a mesh or subset (through iRel?)
  - copy
  - extract a list of numbers/values in some order for the user
Manipulation operations
   - should we be able to collect fields into sets - that is a container
     of fields?
Advanced Operations
Moving forward
Leads:  Mark M. and Carl O.-G.
Subcommittee:  Mark S., Tim T., Harold T., Xiaolin L.
Need a glossary of terms - well defined
   - everything required to define a field, e.g., dimensional analysis
Data model (domains, fields, distribution functions)
   - how to handle coordinate fields
   - UML diagram of relationship among them
Show how this applies to the use cases - do we have the right abstractions?
Socialize with ITAPS team
Socialize with external experts/users
   - Related Technology: SIERRA, Overture, Intrepid, VisIt, Solvers/TOPS
   - Internal services: Mesquite, Frontier, Swapping, Zoltan, meshAdapt,
meshI/O
   - Users: SLAC, Nuclear energy, Subsurface (PNNL)
Want to understand competitors: Matlab, vtk/Kitware, Simmetrix, FEL
Iterate
   Define functions
   Create implementations
Interaction model
  - Email alias - itaps-fields
  - Mark and Carl work on first two items; create working document; flat text
  - Revision control
  - Send to subgroup and iterate - 4 weeks
  - Use cases - subcommittee helps
Software Quality Discussion
Compliance test suite still doesn't cover 3D modification and
iterators once the mesh has changed;
Tools - buildbot or hudson - in place by Halloween or mid Nov - Ellen
Grab and build
  - GRUMMP, MOAB, FMDB, NWGrid, CGM/Lasso ScorecModel
  - Compliance tests : iMesh, iMeshP, iGeom, iRel
  - iZoltan, Swapping, VisIt, FronTier, iMeshIO, meshAdapt, eyeMesh, Mesquite
Everything will start on the Mesh Machine - Tim
Time Line for iMesh tests
  - iMesh compliance tests - Christmas - GRUMMP, MOAB, FMDB, NWGrid
  - iZoltan, VisIt, FronTier, iMeshIO, Mesquite
     - Christmas for GRUMMP/Moab/FMDB, NWGrid may be longer
  - Swapping - Martin Luther King Day
  - iGeom compliance test - July 4
  - CGM/Lasso - July 4
  - ScorecModel - Labor Day
  - meshAdapt - Labor Day FY10 for FMDB, Thanksgiving FY10 for GRUMMP, MOAB
  - eyeMesh - build test against all implementations; Christmas 09
  - tutorial examples - Valentine's day
iMeshP Compliance tests - Karen and student?
  - read in the whole mesh on every processor and test iMeshP functionality
    against the known solution
  - creating an iMeshP compliance test is a problem
  - start with MOAB unit test and see what covereage we have along
    with FMDB and use in iZoltan and Mesquite
iGeom Compliance tests - Tim and Jason
  - ASIS is a common format for the two implementations
  - current compliance test reads in a model
  - query tests for a start would be nice
  - July 4 for compliance test, CGM
  - Labor day FY10 for ScorecModel
  - Mesquite iGeom test Thanksgiving FY10
iRel Compliance tests
  - primitive test for LASSO - reads two files and associate things
  - exists; relies on iGeom but is ready to go into the test suite
Vertical Test Suite
  - come back to this after the basic infrastructure is in place
Release Schedule
  - First major release at Valentine's day FY10
  - New releases every 6 months thereafter
  - Need release notes for the framework and each package
  - Include new features of each package
  - create template for each package
Performance Testing needs to be done - in place by Christmas - Tim
  - need representative kernels of computational kernels
  - need to profile the kernels
  - examine memory and time
  - use calgrind to produce output file; would like to look at variance
    between implementations
  - Tim has a computational kernel he can use
Documentation - Ellen and X?
  - API reference manual through doxygen
    - add a list of error codes a function can return
    - performance guarantees
  - start with ACM Toms document as a user guide
  - add the tutorial examples and some text
Other items to add: - Mark Miller
  - Header number to understand what to link against and be able to check it
    - iMesh.h check only - for any .o that's brought in - this checks that
      all files were compiled against the same .h
  - Release notes have been very helpful
Versioning the interface
  - first major digit - major changes to the interface
  - second digit - minor updates or additions to the interface
  - third digit - bug fixes, backward compatible
Wiki - Tim will set this up
  - use this to track proposals
  - see if we can set this up at Argonne
  - nice to have repository and wiki in the same place
Lori Freitag Diachin
Center for Applied Scientific Computing          Tel:  925-422-7130
Lawrence Livermore National Laboratory         Fax: 925-423-2993
P.O. Box 808, L-561                                     Email:
Livermore CA 94551
More information about the tstt-interface mailing list
