Some fields input.
Mark Shephard
shephard at scorec.rpi.edu
Sat Oct 17 11:01:29 CDT 2009
This email is primarily for Mark Miller and Carl who are charged with
the task of starting a iFeilds document.
Since many of the requirements discussed at the bootcamp this week are
the same as what the RPI team was using in 04 when we started the
attached document, I thought Mark and Carl could benefit by seeing some
of the things we were attempting to do. Although we often used different
terms this week, one will see this document attempts a structure for
fields that deals with many (not all) of the requirements we discussed
for at least mesh level representations of fields. There is no claim
that this structure is ideal of the one we should adopt.
The .fm file is for Mark Miller since he is one of the other 5 or so
remaining Framemaker users left.
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/tstt-interface/attachments/20091017/261e8189/attachment-0001.pdf>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/tstt-interface/attachments/20091017/261e8189/attachment-0001.txt>
Type: application/msword
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/tstt-interface/attachments/20091017/261e8189/attachment-0001.doc>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/tstt-interface/attachments/20091017/261e8189/attachment-0001.obj>
More information about the tstt-interface
